Results 1 to 2 of 2
    Are 9.74 calipers same f/r?
    Two brake questions:
    1) I have a spare front Hope Mono Mini post mount that I'd like to use as a rear caliper with a WI ENO eccentric mount. Are all post mount calipers the same? In other words, if it works with a 160mm rotor in front, will it work with a 160mm in back?
    2) Semi-related question. I also have a rear 160mm IS mount caliper, I think I remember that a rear IS 160mm caliper is the same as a front 180mm IS mount, can anyone confirm?
    Ben
    Got the answer from Hope, the rear #3 is the same as my existing front, so swapping a 160r caliper to a 180f rotor will work without adaptors and the post mount front will work fine with the ENO eccentric, so all's sorted after a bleed. Excellent!
