Results 1 to 2 of 2
    RML
    RML is offline
    Mar 2006
    74 mm post mount fork and 160 mm rotor
    Dumb question...
    Have two forks, one is a post mount 74 mm, i have hope mono mini 07 with 160mm rotors. I should be able to mount them directly without upsizing the rotors? I read somewhere that with marz post mounts, you need to use 170 mm rotors...
    The other fork is a 51 mm IS. The hopes came with an adapter for the IS, again, should i be able to mount the mono minis with the adapter, without having to upsize the rotor.
    Thanks!!!!
    ups and downs
    If they're a post mount caliper that uses an IS adapter then it should work with a 160mm rotor on either fork. If it's an IS caliper that uses a PM adapter for PM forks, that would need a bigger rotor.
