Results 1 to 5 of 5
    Keep it greasy!!
    May 2005
    6" to 8" rotors pros and cons?
    I've warped 2 front 6" wavy rotors with my juicy 7's during average crosscountry riding in Vt. where the hills are long. Would going to 8" make that much of a difference. Is just changing the front the best or both ?
    Thanks to all!
    Authority is dead!
    Reputation: Lucky13's Avatar
    Change front as you use it the most. If you have $ and don't mind extra weight, change both.
    For the love of Oi
    Rent a house at Attitash
    DSR
    DSR is offline
    Yeah, except that I've found that the bigger rotors are more susceptible to warping, at least with my old Hayes 8" rotors. And heavier, if that matters. And that you'd need a new caliper mount. S
    "El Whatever"
    Reputation: Warp's Avatar
    Quote Originally Posted by Who Dat!!
    Thanks to all!
    If the hills are long and steep, you might want to swap out the rear one too. Here in Mexico City we have long steep hills where you want to use your front brake the most but always support it with the rear... the rear brake gets less fresh, clean air so if you drag them lots (like on long steep stuff) they'll warm up a lot and a bigger rotor is desirable.
    Check my Site
    Quote Originally Posted by DSR
    To put the "weight issue" in perspective, the difference between the Hayes 6" and 8" rotors is about 80 grams, or 3 ounces. I also debated the weight difference, until I realized it's equivalent to one sip from my 70 oz. 1984+ gram hydration pack. Good luck. - Dave
  1. Pros / Cons of Boone Ti Chainrings
    By floydg68 in forum Weight Weenies
    Last Post: 05-05-2005, 08:45 AM
  2. 40X20 vs. 36X18 vs. 32X16 pros and cons?
    By Mountain Cycle Shawn in forum Singlespeed
    Last Post: 03-25-2005, 06:07 PM
  3. Replies: 0
    Last Post: 10-30-2004, 04:34 AM
  4. 24" wheel pro's / con's?
    By keen in forum Downhill - Freeride
    Last Post: 10-02-2004, 09:40 AM
  5. Pros & Cons of different nipple lubes
    By Steve-O in forum Wheels and Tires
    Last Post: 01-16-2004, 10:13 PM
