Results 1 to 6 of 6
    Reviewer/Tester
    Reputation: Rainman's Avatar
    From 6" to 8" on front disc..??
    I have been thinking about going to an 8" disc on the front of my VT-2 for a few months.
    Are there 'kits' available to do this, or, what would I need to do this conversion, and where can I buy it?
    The current brakes on the bike are standard Hayes nines.
    Thanks..
    R.
    Bikeaddict
    what you need is ...
    A new rotor and a caliper adapter... probably cost $60 total. Hope, EBC etc make both, not sure about Hayes. Watch out for warranty issues on your fork. Other than that, brilliant. Apparently, the math determines it gives you about 40% extra stopping power, which seems loads but it simply turns good brakes into brilliant brakes and, despite what some people say, its not over-kill for XC/trail unless you're racing.
    Reviewer/Tester
    Thanks for the info.. I'll chase it up.
    R.
    mtbr "member"
    Reputation: Reek's Avatar
    Definitely 8 inches...
    Quote Originally Posted by Rainman
    R.
    Been a big proponent of 8 inch front rotors since way back when I had a Marzocchi Z1 alloy in 98. Hayes used to make a adapter for the fork's funky tab spacing but only had an 8 inch rotor option - no 6 inch AT ALL. I was really pissed at first. Then after riding a season, I converted all of my bikes to 8 inch font and 6 inch rear, and have done so ever since. Never had a problem with QR's or disc tab failures on various brands of forks but I mostly stick with Marzocchi and White Bros.
    Check out Universalcycles.com for cheap Avid adapters. They run about $9. And don't worry they'll work with Hayes systems. I have a mix of Avid and Hayes adapters on my bikes, no problems. Hayes 8 inch adapters for QR forks are REALLY hard to find or are expensive.
    REEK
    Reviewer/Tester
    Yay!! thanks mate..
    I'm going to go get me some asap.
    R.
    Reviewer/Tester
    Got the 8" disc on the front of the VT. WOW !! Stopping power !!
    R.
  1. Mechanical 8" front disc, Levers ???
    By BottomFeeder in forum Brake Time
    Last Post: 05-04-2005, 05:29 PM
  2. 6" to 8" disc upgrade
    By Coiler Mad in forum Kona
    Last Post: 01-27-2005, 05:53 AM
  3. 2004 SJ FSR Exp. Disc - shuddering front brakes
    By Richie in forum Specialized
    Last Post: 01-11-2005, 10:39 AM
  4. Switching 6" Promax disc brakes for 8" Avid Mechs
    By Phat Tire in forum Brake Time
    Last Post: 08-19-2004, 08:12 PM
  5. opinions on 6" front 8" rear
    By ashayk in forum Brake Time
    Last Post: 06-25-2004, 01:59 PM
