Results 1 to 61 of 61
    22mm chain stay disc brake adapter
    I looked around on-line for an adapter to get disc brakes on the rear of my 99 Klein Attitude Comp and I couldn't find anything that worked so I had a local laser and fabrication shop make me one (I am friends with the owner). I found out that there is a demand for these on the market so we made a few. The adapter gets the calliper above the rear seat stay which is the issue with the other adapters on the market. It works with Trek, Klein and Schwinn models that all have that same 22mm chain stay mount pattern and is designed for 160mm rotors. Unfourtunately my picture file sizes are too large for this format. If you would like pictures or information regarding this you may contact me at nanoseth@yahoo.com!
    Reputation: vk45de's Avatar
    You mean something like this?
    B A N N E D
    nnn
    nnn is offline
    Reputation: nnn's Avatar
    Feb 2005
    Neither of those 2 are what is being posted here.
    The first one is for Hayes mounts on the seatstay, some frames have them on the chainstay.
    The A2Z is universal but I found it couldn't work on my frame with a Hope ProII QR hub.
    "Life begins at 140" Richard Burns
    http://www.nikolay-k.com
    Person
    Quote Originally Posted by nnn
    The A2Z adaptor should work if you use a front caliper on the rear.
    Nope. I am talking about using satndard callipers on a rear chain stay 22mm mount pattern for a 160mm disc brake rotor. The A2Z AD PMR doesn't work with most bikes and callipers because of conflict with the seat stay. This adapter gets the calliper up above the seat stay where all the bikes today have their callipers mounted. It works with Hayes, Shimanno and Avid that I know of and probably all the other ones with IS mounting pattern too.
    Person
    Quote Originally Posted by nanoseth
    But my point is you can make that A2Z adaptor work if you simply use a front caliper with it. I did that on an old Schwinn and was able to keep using a 160mm rotor. A2Z states you must use a 180mm rotor with the adaptor. When you use a front caliper it does not get pushed out as much, thus eliminating the conflict with the seatstay.
    If you are trying to sell the adaptors you made on the forum I suggest you buy an ad to keep the moderators happy.
    No, he mentioned he had IS calipers so he would need a front caliper in back to run 160mm rotors.
    B A N N E D
    22mm chain stay adapter
    I will look into putting an advertisement up. Thanks.
    Hey I am needing this adapter I have a 99 8500 Trek WSD
    I am wanting to install Avid BB7 mechanical disk brakes. Where do I buy one
    B A N N E D
    Quote Originally Posted by Judacator View Post
    I don't think that you can buy that adapter anymore, I don't think that it was a great design and I suspect that there would be some flex with that adapter too.
    I'd stay with a rim brake on the rear and put a disc brake on the fork.
    Thanks I guess my next step is to cut the seat stay and weld an IS standard disk brake into it
    B A N N E D
    I wouldn't.
    If you were to weld on a brake mount you wouldn't need to cut the seat stay.
    If you do weld on a brake mount are you also going to re-heat treat the aluminum frame afterwards?
    I see this old thread has been revived a few weeks ago. I have a 99 Mantra and want rear discs too. Anyone have a viable fix? I have threaded holes 22mm apart on the non-driveside chainstay. Hope there are suggestions. I haven't been able to find a brake with holes 22mm apart...
    Reputation: shiggy's Avatar
    Dec 1998
    Re: 22mm chain stay disc brake adapter
    Quote Originally Posted by lucky53s View Post
    Nothing has changed except demand is lower than ever.
    mtbtires.com
    That isn't reassuring...
    Dec 1998
    Not meant to be. That brake mount has not been used for 15 years.
    mtbtires.com
    Neither has a carburetor but I can still buy parts.
    Dec 1998
    Very poor comparison.
    There have been many hundreds of millions of carburetors made in the past 100+ years, many of which no longer have parts available.
    There may have been a thousand or two 22mm calipers made over 2-3 years. Spare parts ended then, too.
    Just keep your rim brake.
    mtbtires.com
    Toronto cycles has some, though there is no guarantee it will fit, so measure carefully to see if you have the required room.
    a2z Disc Brake Adapter, A2z DM-UNI, AD-PMR, A2z Components
    I know you're much more of an expert than me but just because a solution hasn't been found doesn't mean giving up is the answer. Maybe you're right and I won't solve this issue, but if I keep my eyes open eventually someone will list a 22mm brake in eBay or another solution will present itself.
    Just because it's hard and unimportant to you doesn't mean it's unimportant to everyone.
    Dec 1998
    You need to be realistic.
    mtbtires.com
    A true optimist.
    Aug 2014
    That makes two of us.... I'm trying to upgrade my 2000 Klein Mantra to disc brakes and have followed the same trail leading to nowhere at present. I bought the adaptor from A2Z DM-UNI but it doesn't fit! I'm not giving up though. The AD-PMR looks more likely but want to hear from A2Z before I waste more money. If I find a solution, I'll let you know.
    B A N N E D
    Quote Originally Posted by Antnbee View Post
    I don't think that the AD-PMR will work on your frame, the angle of the seatstay/chainstay on your frame would be too small.
    You can see some photos of the AD-PMR on the following thread.
    Where can I get this..!? Post mount to IS adapter...?
    The Brake Therapy conversion would work but it's expensive.
    http://2btherapy.com/bikes/brake-therapy-conversion-kit
    Aug 2014
    Ouch, that's expensive. I think I've seen a photo with an AD-PMR running a Mini Hope front on the back but I don't think it was a Mantra. Annoying as I bought a secondhand set of disc specific wheels and some new Avid Elixir 5's to go on the Mantra and the rear mount is the sticking point. Might have to shelve the Mantra and buy a new frame!!
    GNR
    GNR is offline
    I have many 22mm setups. I've sold 20+ in the past year, used, brand new, for parts, etc. and I've got several left.
    BTW...People who are trying to ride or build should be encouraged and not discouraged...if you're a jerk in real life, realize you have a second chance to be nice in your online life...try it.
    Aug 2014
    Sounds great..how can I get one? How much?
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Well you can probably resell it to recoup most of that cost after the Klein fails (former Klein owner here &#128515
    I'm just keeping my Mantra as a primary bike until I save up the cash to build an On-One Parkwood (I think). Then the Mantra will become my wife's trail bike (aka, walking paths) and I will still get to keep it. She's almost as tall as me so a shorter stem and lower seat will fit her fine and will be nice and squishy for her.
    GNR
    GNR is offline
    Pm'd you.
    The crown jewel! A 22mm Hayes brake for my Mantra. Thanks GNR!22mm chain stay disc brake adapter-imageuploadedbytapatalk1407856358.369857.jpg22mm chain stay disc brake adapter-imageuploadedbytapatalk1407856367.182227.jpg
    Do you still have any of these around? i really could use one
    GNR
    GNR is offline
    Quote Originally Posted by wet_buffalo@yahoo.com View Post
    Yep. I've got a few left. clmd17 at hotmail dot com is my direct email.
    Let me know what size frame or how long you'd like the rear hose, and if you need a front brake to match. Let me know and I'll make what you need and get you some pics. Best, Laurence
    Apr 2014
    Me too. Emailed you. I call dibs on one until I can tell you what hose length I need.
    This thread is a few months old, I know, but just FYI I installed a Brake Therapy kit on my '97 Klein Mantra several years ago (with BB7's) and it works great!
    B A N N E D
    Quote Originally Posted by dman_mb1 View Post
    Just a few, it was started in 2009.
    The cost of those adapters is too high, most people can't justify paying that much.
    GNR
    GNR is offline
    Still have a few Hayes 22mm brakes
    I still have a few 22mm brakes sets, as well as a few brand new 22mm calipers. Can assemble a brand new brake or two as well.
    Quote Originally Posted by GNR View Post
    Any of these still floating around? I am getting tired of searching for a decent adapter.
    GNR
    GNR is offline
    Hi,
    I've got one unassembled 22mm caliper left in my bin. Complete build kit included as well as some excellent but not new pads. I don't have any complete master cylinders, but I've got new parts to construct one.
    PM me if you're interested. Best, GNR
    Mar 2015
    Have you tried the vintage section?
    "you must do what you feel is right of course"
    Mar 2015
    Also,take at the Retrobike forum in the uk
    I have a machinist that is creating a mount. He has been through 3 versions so far and found one that is working. Made out of aluminum and has yet to allow flexing. We are starting the process to trim things down and make it look better.
    22mm chain stay disc brake adapter-img950341.jpg22mm chain stay disc brake adapter-img950342.jpg22mm chain stay disc brake adapter-img950343.jpg
    B A N N E D
    Quote Originally Posted by literleaner View Post
    If I was going to make a bracket like that, I would make it as short as possible and also clamp it to the seat stay.
    * If the brake caliper was in more of a 45° angle there wouldn't be such a big loop with the brake hose.
    * The brake caliper doesn't look to be correctly positioned properly over the rotor.
    Brake pads should never overhang the outer edge of the rotor.
    Overhanging pads don't have as much stopping power and will eventually cause brake failure when the unworn parts of the pads touch each other.
    Quote Originally Posted by cobba View Post
    Thank you. I sent this over and he modified the mount. Unfortunately it is ungodly huge and due to the tolerances/space/clearance I don't think I am able to reduce the footprint...
    Needless to say the search continues for a Klein Mantra solution for discs
    22mm chain stay disc brake adapter-20160204_103157.jpg22mm chain stay disc brake adapter-20160204_103203.jpg
    Well I searched and I met the best vintage guru I believe exists. He provided an older set of Hayes Mag's as well as the parts needed to rebuild. I then purchased a set of Jagwire hydraulic lines and went to work. Overall I have approximately $160 invested in these but without a doubt they are dialed in. New masters, new lever pins, new bushings, and new lines. I can't wait for my wheelset to arrive so I can finish my project.
    22mm chain stay disc brake adapter-20160222_221517.jpg22mm chain stay disc brake adapter-20160222_221551.jpg22mm chain stay disc brake adapter-20160222_221743.jpg
    Mar 2016
    In need of a 22mm bracket....
    I am in the market for a bracket to mount a modern disk brake caliper to my Klein. Anybody have a spare they want to let go of? Thanks...
    22mm chain stay disc brake adapter-20160316_153122.jpg22mm chain stay disc brake adapter-20160316_152915.jpg22mm chain stay disc brake adapter-20160316_152908.jpg
    Apr 2016
    HI everybody,
    I am currently trying to get brakes on a 1999 Trek 8900. I am told the proprietary Hayes brakes are no good BUT I have also been told a lot of BS from multiple LBS. I am about to order the AD-PMR adaptor for the rear ( I got the front working the other night by putting on a front disc brake I trashed picked off of a Mongoose.) If I have to create my own bracket so be it, wont be pretty but it will work.
    SO I guess my questions are....
    Will the AD-PMR adapter work?
    Is anyone selling parts that will put disc brakes on the rear?
    Is anyone still making adaptors and would they work on a 1999 Trek 8900?
    Thank you to anyone willing to help! I will let you know what I end up doing.
    B A N N E D
    Quote Originally Posted by Ouchie View Post
    Maybe, maybe not.
    The geometry of the frame and the type of caliper are a couple of things that need to be taken into consideration.
    GNR
    GNR is offline
    I've got 22mm calipers and complete rear brakes to sell if you'd like one. You can PM me here or respond here. Best, GNR
    May 2016
    I have a '98 schwinn with hydraulic brakes. I need a rear brake. What's the price and condition?
    Regards,
    Anthony
    GNR
    GNR is offline
    Hi,
    I've got calipers, whole rear brakes and sets...which would you like? If you need a whole brake or set, let me know the hose lengths and I'll put something together.
    I typically receive $130 for a set, $100 for a whole brake and $75 for a good caliper.
    PM me here if interested and we'll go from there.
    Best, GNR
    May 2016
    Hello GNR,
    I assume the whole brake includes the lever/with reservoir, cable (60 inches) and caliper with pads. The mounting bolts on the caliper are approximately 1" apart. I want to keep the bike looking as original as possible.
    Please advise.
    Anthony
    May 2016
    Hello GNR,
    Please send me your phone number or call me at 386-439-2172.
    Thanks,
    Anthony
    GNR
    GNR is offline
    Still have a few...just saying. GNR
    Mar 2016
    Did we all give up?
    The 'Toronto Plate' works okay but not perfectly. Going with an original set-up is the only way. So... 🤔
    Maybe creating adapter for roadbike style flat caliper would be feasible? It shouldn’t require as huge adapter as IS brake.
    I used the PMR adapter for size S ’99 Attitude, it kinda works but brakes are howling like crazy due all the flex and vibration. Went back HS-33 on the rear due noise.
    Has anyone tried this one? The photo looks identical to a Klein.
    https://www.ebay.com/itm/New-A2Z-AD-...19.m1438.l2649
    2001 Klein Attitude Resto Mod Complete! HA! Mods put in TREK Forum. Gotta love it.
    There is also this thread but still trying to find out who the connection in NY is.
    Quote Originally Posted by PhotoGus View Post
Name:	Screen Shot 2018-05-04 at 12.33.36 PM.jpg
    Looks just like the adapter discussed in most posts above.
Members who have read this thread: 41
