    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    New question here. 203/185mm rotors with 200/180mm adapters?
    Hey,
    I am basically trying to figure out if I can swap one wheelset between two bikes. The wheels and bike #1 would have 203/185mm avid elixir brakes & rotors. The second bike would have formula brakes on with 200/180mm adapters.
    I was thinking I could use chainring spacers (or similar) between the formula calipers and adapters, to create the extra 3-5mm clearance needed for the larger avid rotors.
    Not ideal, but would it work?
    Provided you have sufficient thread bite, into the brake adapter, I see not reason why this would not work...Blue Loctite is your friend as well.
    B A N N E D
    Quote Originally Posted by FM View Post
    Halve those numbers if you want to pack the calipers out, you'd only need 2.5mm for the 185mm rotor and 1.5mm for the 203 rotor.
    FM
    FM is offline
    Apr 2003
    Quote Originally Posted by cobba View Post
    Oh, that makes sense, and makes the change even less radical....enouraging...
    FWIW, I had to use chainring spacers on my stock avid elixir XO's to keep the rotor from rubbing vertically on the inside of the caliper. Seems to work fine...
  1. Avid BB7 180mm OR 185mm
    By Hkp2000 in forum Brake Time
    Last Post: 09-16-2011, 10:13 AM
  2. 180mm vs 185mm
    By hardwarz in forum Brake Time
    Last Post: 05-27-2011, 10:14 AM
  3. KCNC 180mm vs G3 185mm??
    By ds33gt in forum Brake Time
    Last Post: 05-08-2011, 04:58 AM
  4. Replies: 3
    Last Post: 01-15-2011, 10:12 PM
  5. Changing Rotors fom 185mm to 180mm
    By cybrscot in forum Brake Time
    Last Post: 10-20-2010, 08:27 PM
