Results 1 to 3 of 3
    Mar 2006
    203 or 180mm front rotor for XTR M985
    I am setting up a new Niner Rip 9 with the OE XTR M985 brakes from jensonusa for 170 a wheel and need to decide on rotors to go with them. I have a stans flow ex wheelset for it with 6 bolt hubs so I am planning to use Shimano XT RT86 rotors. I was thinking about running a 160mm rear but split between the 180 and 203 in the front. Does anyone know the weight difference between these rotors? I am only 175lbs but I don't want to compromise on braking if its not too big of a weight penalty. Any other rotors that are better for the same price or less?
    Cannonball!
    Reputation: coiler-d's Avatar
    Sep 2004
    In my experience those are very powerful brakes, 203 may be overkill!
    Reputation: Tillers_Rule's Avatar
    Sep 2004
    I'm 200 lbs with an XL RIP 9 and the 180 up front is perfect. No issues bringing the bike to a stop on ~25mph downhill sections. I'm running Stans Arch EX rims, which are a bit lighter than the Flows. But I also run Kenda Nevegal which on the heavier side at ~800 grams.
