Results 1 to 2 of 2
    2012 XO rear brake hose
    I want to lengthen my rear brake hose so I can internally route. I have the silver 2012 XO brake. I see the hose kit for around $35 however do I need to buy he bleed kit if I install fresh line?
    Tool
    Reputation: Pedalphile's Avatar
    Yes, you'll want a means of bleeding. You may be able to find a way to fill the new hose and not introduce air to the system in the process of installing it, but you will likely need to bleed.
    -Pete
    I can barely get my mouth around it.
