Results 1 to 28 of 28
    Reputation: iwantalitebike's Avatar
    2012 shimano xtr vs. xt
    other than weight, what are the advantages to purchasing the xtr brakes over the xt brakes. i kinda torn on which ones to get. someone enlighten me!
    I ride a bike, therefore I am!
    SLO Town
    They are the same... other than finish and weight.
    Save some money and buy the XT's
    Best brakes ever!!
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    Well, the XT only comes with ServoWave. If you don't love it, then the XTR Race is your only option.
    XTs are reportedly more powerful.
    XTRs have a 1 piece caliper.
    Check out my SportTracks plugins for some training aid software.
    Reputation: 006_007's Avatar
    Do we know the weight difference between the two?
    g3h6o3
    Oct 2007
    I've read about 40g
    hmmm, now i need to decide if 40g is worth the $175 difference in price for the set (assuming its 40g for the entire set?)
    g3h6o3
    Oct 2007
    Quote Originally Posted by 006_007 View Post
    I think it's for the full set but it was a post on these forums so I'm not sure how trustable the source is (and what exactly was being compared). In the end, when comparing the XTR Trail to the XT, it's a matter of aesthetics more than anything else. If you go for the XTR Race however you get a different brake feel because of the lack of ServoWave.
    Quote Originally Posted by PissedOffCil View Post
    Ya, I am comparing the xtr trails vs the xt.
    Think I may as well save the $$$ for only 40g.
    Does anyone know how much $175 weighs sitting in my wallet - cause my brakes will be 40g heavier plus the weight of that fatter wallet my bike is gonna be a pig lol
    g3h6o3
    Oct 2007
    The only reason I got the XTR Trails instead of the XTs is that the XTs weren't out yet and I was tired of waiting for them.
    empty beer member
    Reputation: WrecklessREX's Avatar
    According to compcyclist the XT is 312g and the XTR race is 210g. The XT come with the cooling finned pads so that needs to be accounted for when comparing the 2. Either way it sounds like performance is great from both. I'm on the fence also.
    Quote Originally Posted by WrecklessREX View Post
    XTR trails have the finned pads as well - so that will for sure be some extra
    Reputation: Dalnoboy's Avatar
    Shimano still use mineral oil... In winter rides brakes are work bad
    That's not true. Shimano used caliper seals that hardened up below freezing which caused poor cold weather performance. They've had revised seals for some time now that resolve that issue.
    Quote Originally Posted by Dalnoboy View Post
    Not a mineral oil issue at all, my Magura mineral oil brakes are great in winter.....
    edit *** car nut beat me to it lol
    40g for front and rear or 102g for just one end?
    It sounds like no one is sure. Get some good data b4 you decide.
    empty beer member
    The weight is listed as per side on competitivecyclist.
    yup, per side.
    XTR trail (w finned pads) = 235g
    XT (w finned pads) = 312g
    So for 200 bucks more i can save 150ish grams. Not bad lol.
    XTR race are the steal though - lighter then XTR trail (210g) and cost 20 per end less........
    Reputation: ravewoofer's Avatar
    Dec 2008
    Not true. I ride in the winter with XTs. Brakes work just as well as in the summer. They're awesome, and there's no way I'd pay extra for for XTR. sometime simple performance out weighs the weight weenie principle.
    Reputation: tburger's Avatar
    FYI, I weighed my XTs with 1350mm rear hose, 85mm front hose, with adapters and finned brake pads.
    (335g + 320g) = 655g for the set.
    RT76 rotors 180/160 plus all mounting hardware = 365g for the set
    aka bOb
    Reputation: bdundee's Avatar
    Pedaler
    Reputation: Nimblewill's Avatar
    Just put some XT's on my new Cysco SS... they are amazing.
    Propedal Off
    Reputation: Sin Wagon's Avatar
    Oct 2011
    Quote Originally Posted by Nimblewill View Post
    New to XT and love them as well. Best bang for your buck IMO
    I have ridden both or the 2012s: XT are a great set of brakes, but I thought the XTR had more power and modulation.
    Note: Don't get the Magura MTs. I found them to be weak and extra parts are hard to come by,
    I love the XTR Trails. Best brake ever, so far. Rockstar power, smooth, quiet. True, absolute one finger braking bliss. You cant go wrong with either, but I am just more of an XTR guy.
    steep fast and loose :)
    Xtr have incredible power to weight ratio. I also run hope evo x2 and they're heavier and less powerful by far.
    Reckon xt would be a good option although STW did a review and suggested they were quite binary...
    HELP! i have a pair of XTR race's that i have been using for 3 months or so....
    Today it was 21 degrees at the start of ride time and the bakes were crap. No modulation in the levers. it felt like the hoses were not letting the calipers compress. i ride with some give in the levers and it was a pinky tap to make them engage today- way too fast! can someone point me to a fix?
    these are late 2011 models and i have 2 pair and im really bummed as they are really $$$ and my avids juicy 7's worked perfectly in all conditions for years. Im worried there is no fix and im out a few hundred bucks. if you cant ride the xtr's in sub 30 degrees they will have to come off and that would be a real shame.
    help?
    Nov 2007
    Quote Originally Posted by jomissa View Post
    If there is no movement before engagement it means the pads are too close. If the pads are too close it means the seals are not doing their job of retracting the pads. Sounds like it could be the same old Shimano seals issue. At least with the Race's you don't have servo-wave so the leverage will be appropriate at contact.
    Having got into this state, the pads are not going to retract of their own accord. Take the wheel out and push back the pads/pistons. This will reset the brakes. If when you next ride in the cold it happens again then it is a Shimano seals problem.
    thank you. i will try this.
  1. Another Shimano SLX M666 (2012) Review
    By jsilva in forum Brake Time
    Last Post: 07-18-2014, 08:40 AM
  2. Replies: 30
    Last Post: 04-23-2012, 05:10 AM
  3. Shimano 2012 XT group
    By PissedOffCil in forum Shimano
    Last Post: 12-17-2011, 12:10 PM
  4. When can I buy the new 2012 Shimano Drive Train?
    By charlesinoc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-12-2011, 06:45 PM
  5. 2012 Shimano XT 2x10 Cranks
    By Shalom in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-09-2011, 12:47 PM
