Results 1 to 19 of 19
    Reputation: jncarpenter's Avatar
    2009 Hope Tech M4 + Hope Matchmaker + Saint Shifter = FAIL?
    Has anyone else had an issue trying to use the Hope matchmaker with Saint shifters on the Tech M4 levers? For some reason, with the shifter attached to the matchmaker, you can't even bolt it to the lever????
    Reputation: Xave's Avatar
    I thought the matchmakers only worked with Sram
    Quote Originally Posted by Xave
    Hope offers a Shimano version they claim is compatible with XT/ Saint.
    ...idios...
    Reputation: SteveUK's Avatar
    Do you have a picture of the failure? Is the 3-bolt mount on the underside with the shifter body under that?
    Diogenes
    Quote Originally Posted by SteveUK
    Yes, exactly as you described. I am charging the camera & will post a pic in a bit.
    A couple pics. You can see that the shift body hits the lever before I can properly tighten down the matchmakers. Plan on calling Hope in the AM to inquire...
    Jan 2009
    i had the clamp on xt shifter, its very close to the bottom cap, but when i mount on the clamp, i screw full on the top screw, then follow by the bottom screw, then i have a 1/2mm gap between my shifter and cap. i emailed hope abt this, then reply the same way of mounting. HOPE should change the design a few mm to avoid this...
    ...idios...
    R&D fail indeed. To allow you to maintain even fitting of the clamp, I'd recommend, and it would be simple enough to do so, to make a shim for the extra .5mm or so that you need; but it really shouldn't be necessary.
    Diogenes
    Nov 2006
    ¿Do they work ok with SRAM shifers?
    I miss the Juicy´s matchmakers after switching from Avid Juicy to Hope M4.
    TIA
    STFU and HTFU. - Fo, circa 2009
    Any idea if these will work with the XTR 970 shifters?
    Jan 2009
    Quote Originally Posted by fcojavier
    TIA
    HOPE do have the clamp for SRAM shifter...
    Jan 2009
    Quote Originally Posted by CJLED
    Nope, its not compatible with XTR shifter
    I do have them for sram shifters on my other bikes, however...I was wanting to run a 5-6 speed rear & sram deraillers are not compatible with that setup.
    Reputation: JChasse's Avatar
    Quote Originally Posted by kianlee
    ouch, really? So you can't run Hope M4s with current XTR shifters!? That would take the Hopes off my list for my next build...
    You can run them with the XTR, but I was interested in using the Hope combination brake lever clamp\shifter mount for the Shimano shifters. I have a set of Tech X2s on a bike with XTR 970 shifters and have achieved a comfortable setup, but wa interested in trying the combo mount to clean up the looks and see if the ergonomics could be improved upon.
    Quote Originally Posted by JChasse
    He was referring to the matchmakers. You can run the xtr shifter separately on the bar.
    I bought an XTR shifter to run with them & realized it only works with the XT & Saint...so I bought a Saint and...well you can see where that got me.
    Knolly Rider
    Has there been a solution to this problem? I am looking at a set of these for my Tech M4/Saint setup and want to know if this was a one-off case or if it is a common issue.
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    I've read about it often. Hope brakes are bulky and it's been a problem.
    For sure you'll wnat their own Shimano compatible matchmaker and to make sure they fixed the problem, give them a call.
    Check out my SportTracks plugins for some training aid software.
    ive contacted hope about this and the problem is because its an older hope brake and the matchmaker isnt meant to be compatible with this lever because of its wider body.
    "hope" this helps
