Results 1 to 2 of 2
    Reputation: rugger4's Avatar
    2007 Avid Juicy 7 PCP Question
    I have an older set of Juicy 7's (2007 I believe--lighter grey with the plastic pad adjust/lever reach knob) and the knob will not adjust the lever in at all although it will turn. I had my local shop look at it and they didn't really have a solution except to replace the whole lever. I was wondering if anyone else had any experience with this and if maybe replacing the knob may help, I am sure the knob actuates something inside the lever that could be the problem as well...
    Old man on a bike
    Juicy 7s have a pad contact point adjustment knob (which is a bite point adjustment, does not change lever or pad position), and a separate 2mm lever reach adjustment screw, which adjusts where the blade sits in relationship to your bar. Here's the manual http://www.sram.com/_media/techdocs/...e_7_Carbon.pdf
    suum quique
