Results 1 to 2 of 2
    Reputation: Gat0rvean's Avatar
    2005 Manitou Nixon Elite +203 Rotor
    I'm replacing my brakes and rotors, putting Clark's Skeletal Hydraulic brakes with a 203mm rotor on. The Nixon is a Post Mount setup, so I've taken the IS adapters off, but the bolts I have (originals) make it so that I can't fit the rotors on . Do I just need bigger bolts and spacers, or is there an adapter I need? (Real noob, so hopefully you can follow, thanks)
    2011 Santa Cruz Jackal
    2011 Trek 2.1
    2007 Santa Cruz Heckler
    you need an adaptor go to your lbs they will have one on the shelf
