Results 1 to 10 of 10
    Reputation: pulser's Avatar
    Dec 2004
    2 piece rotor VS 1 piece
    I seem to over heat and warp rotors allot. Any one have any experience with then new 2 piece ones for mountain bikes? I know they work really well for motorcycles. Are they worth the extra money for the mountain bike?
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    They won't shed heat any better and in fact, my 2-piece rotors warp much easier than their 1-piece counterpart.
    Perhaps you need to upsize your rotors, change your pads, and/or change your braking techniques if you are regularly warping rotors. A given size rotor can only hold so much thermal energy, and once you move beyond that it needs to go somewhere (hubs, calipers) or you loose braking performance.
    Two-piece are lighter and can be made to shed heat faster - some center sections are formed as a sort of fan that will move more air over the friction surface as the wheel rotates. They aren't going to be a solution for warped rotors themselves.
    Dec 2004
    Quote Originally Posted by Okayfine View Post
    I was thinking about going to a 7" in the front. Its hard to brake less. I am on the Colorado front range. So we have allot of long vary steep down hills. And I have been spending allot of time chasing a friend that is a pro. The brakes get allot of abuse.
    007 is offline
    b a n n e d
    Jun 2005
    What brakes are you running?
    Helmetless Crasher
    Reputation: Stumpjumpy's Avatar
    Could be poor braking technique. Generally, you should be either "on" the brakes or "off". Riding the brakes or repeatedly braking too soon will over-heat them.
    Let go, Luke . . . use the force . . .
    '95 M2 StumpJumper FS
    '11 Cannondale RZ 120-two
    Dec 2004
    Quote Originally Posted by OO7 View Post
    Was running Avid Elixir Cr's. I just switched to Hayes Stroker Trails with the new 29er.
    Dec 2004
    Quote Originally Posted by Stumpjumpy View Post
    Or it could be I spend too much time way back behind my seat picking my way around the rocks.
    LightJunction.com
    Reputation: lightjunction's Avatar
    I like my 2-piece rotors, but mostly for weight benefits. You could try the new Shimano Ice-Tech rotors if heat warping is a serious issue. They claim to have heat dissipation dialed with those.
    We sell quality bike headlights and flashlights.
    www.LightJunction.com
    Quote Originally Posted by pulser View Post
    I am on the front ranges of the canadian rockies...steep and rocky...
    I used to cook rotors regularly.....never warped one.....I had a 160 mm shimano two piece on front and rear....
    Then I got a 210 mm shimano two piece for the front....no overheating ever since.
Members who have read this thread: 8
