Results 1 to 2 of 2
    Mar 2011
    185mm rotor with XT 785's
    Hi all,
    Just want to know what you all think of this setup. I have a 185mm front rotor on my blur. I used the adapter that is for 180mm rotors I jut put the little adjusting washers under the caliper instead of over. Do you think this will have lasting repercussions? Or should I just invest in some 180mm rotors.
    Reputation: Shalom's Avatar
    Nov 2008
    Should be fine. Another option that will be cheaper than new rotors will be new adapters. There are plenty of 185mm options out there. Can't see why they wouldn't work.
