    DB4L
    185mm-203mm Rotors on sid?
    Will a Rock Shox SID Race take the stresses of larger rotors?
    Never trust a fart
    Reputation: frdfandc's Avatar
    185mm is the max size recommended by Rock Shox.
    wants a taco
    Reputation: nubcake's Avatar
    Nov 2007
    id say if your feeling the need for rotors that big you should also feel the need for a beefier fork but as was just said, 185 will fit for sure
    Jul 2003
    Quote Originally Posted by Sunn Xchox
    As noted 185mm is the max recommended rotor size for the NIEW SID with 32mm stanchions etc. Most models prior to the reworked newer model (28mm stanchions) were only rated to 160mm rotors. Depends on the year/model of SID you are talking about.
    Good Dirt
