Results 1 to 3 of 3
    Jan 2011
    180mm rotors w/ Avid Juicy 7's possible?
    I've got Avid Juicy 7's w/ 160mm discs front and rear. Recently bought new alligator serration discs (160mm for the rear and 180mm for the front) cause they're cheaper (1/3 the price of avids) and lighter.
    Saw this post and thought it'd be easy to run 180mm up front. Running 180mm rotor on Avid Juicy or Elixir brakes
    However, I can't find the right adapter. My fork is a Fox F29 RLC w/ post mounts for the brakes. The post above says a rear 160mm adapter will work with a 180mm rotor up front. All the rear 160mm adapters I've seen are IS adapters which wont work with my fork obviously.
    Anyone know an adapter that will work?
    Jan 2011
    might have just found my own answer. anyone think these are a BAD idea for any reason?
    http://store.icyclesusa.com/origin8-...0mm-p5696.aspx
    Nope the appropriate addapter to match the size rotor you are looking to go with is all you need. Have fun!
