Results 1 to 2 of 2
    Reputation: dankist4x4's Avatar
    180mm rotor w/ Juicy 7s?
    Is it possible to run a 180mm w/ avids or shoulde I spend the 20 or so bucks for 185mm rotors.
    1ST RATE Earnest Borgnine-Ethel Merman erotic nudes!óDANGó Ethel was WAY hairier
    Never trust a fart
    Reputation: frdfandc's Avatar
    You can run the 180mm rotors, but you will need to use 180mm brake caliper adapters from either Shimano,Hayes, etc.
    If you don't want to buy new adapters, then just stick with the 185mm rotors.
