Results 1 to 7 of 7
    Jun 2012
    180MM Rotor Options
    Looking for some advice on 180mm Rotor Options. I'm a 215 lb rider riding aggressive XC. I've got Tektro Draco brakes (may replace at some point) with 160 mm stock.
    I recently upgraded to 180mm Avid HS1 along with a pad change and seating. Started with great stopping power, but I cannot get over the noise. I've cleaned them 3 times in the week I've had them on. The longest they have lasted was about an hour before ear splitting screech on both. By the end of a 5 hour ride I was ready to throw my bike.
    Just switched back to the stock rotor, near silent now. I really like the added power with the 180's but I don't want to piss off every other trail go'er. Any suggestions on other rotors?
    Shimano SLX RT66 rotors, bought a set 180/160 at REI for less then $60. They work a lot better then my CleanSweep g3's (paired with Shimano m596 brakes so that may be why).
    Interplanetary Poultry
    Reputation: scatterbrained's Avatar
    I've had great luck with Hayes.
    Editor In Chief, "Internet Tough Guy Magazine"
    "Home of Chuck Norris' Keyboard"
    WillWorkForTrail
    Jun 2012
    Consider the Ashima Airotors. Mine stay quiet, even though I only use Avid brakes, which are supposed to be noisy no matter what.
    Ow!
    Reputation: clydecrash's Avatar
    Apr 2005
    My go-to rotors are Magura Storms. Never a problem, and they seem to solve the noise problems.
    gone walk about
    Reputation: nvphatty's Avatar
    Mar 2012
    As you will soon find out it's all trial n error with various brands, sizes etc. The harmonics of braking systems on certain frame material is a key factor in noise reduction. The same brake components can be used on a steel frame and be awesome, yet used on alum and squeal like a 3 headed chicken.........but then used on carbon with only a hint of squeal. Take the same brake setup but use a 180mm rotor and the reverse may show.
    "ORANGE IS THE NEW BLACK"
    Another vote for the Ashima Airotors, I've put these on two bikes running Avid Elixir's (XO and CR). They eliminated the squealing and also seem to help brake modulation for me.
  1. BB7 w/180mm Rotor
    By datmony in forum Brake Time
    Last Post: 10-10-2012, 04:09 AM
  2. Will my fork work with a 180mm rotor?
    By bikeman1 in forum Brake Time
    Last Post: 05-05-2012, 02:17 AM
  3. Rear BB7 with 180mm rotor- 2 ?'s
    By bitewerks in forum Brake Time
    Last Post: 12-14-2011, 02:12 PM
  4. 165mm vs 180mm rear rotor
    By drivengsxr1000 in forum Brake Time
    Last Post: 10-29-2011, 08:09 AM
  5. 180mm rotor question
    By Gilly32 in forum Brake Time
    Last Post: 04-16-2011, 08:19 PM
