Results 1 to 7 of 7
    Feb 2010
    160mm to 203mm Brake Rotor swap
    I have a Specialized Enduro 29er and am currently running a 203mm rotor on the front and a 180mm rotor on the back. I realized I have a spare 203mm rotor so I was planning on sticking it on the rear to replace the 180mm. I guess the frame is naturally built for a 160mm rotor so to get the 180mm on it there is a brake adapter.
    So before installing the 203mm rotor I bought the 203mm Shimano adapter - I tried to install the 203mm adapter, only to realize that the adapter is only meant to upgrade from 180mm to 203mm (not 160mm to 203mm). I tried double stacking the 180mm adapter and 203mm adapter, which probably would have worked but the screws weren't long enough to accomodate this.
    What is the proper way to put a 203mm rotor on a 160mm frame? Any help is much appreciated.
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    sounds like you bought the wrong adapter.
    I resolve to constantly assert my honest opinion on anything and everything - whether it is requested or not.
    Bucky the Cat
    Out spokin'
    Dec 1999
    Quote Originally Posted by mtnbikej View Post
    This made your post count go up by one.
    =sParty
    disciplesofdirt.org
    B A N N E D
    160mm to 203mm = SM-MA-F203P/P
    180mm to 203mm = SM-MA-F203P/PM
    the shimano adapter SM-MA-F203P/PM doesn't work with some brakes like hope e4. I found out the hard way.
    Reputation: ColinL's Avatar
    Feb 2012
    Well of course. The shape of the adapter is designed around the shape of the caliper.
    Not surprisingly, hope has their own adapters: http://www.chainreactioncycles.com/m...r/rp-prod13728
    Quote Originally Posted by givemefive View Post
    Sent from my XT1635-01 using Tapatalk
    Sep 2014
    Frames have a maximum supported rotor size, the jump from 160 to 203 sounds like it might snap your chainstay in half under hard braking. Make sure your bike supports 203mm first.
  1. Replies: 3
    Last Post: 06-13-2016, 03:19 PM
  2. Replies: 1
    Last Post: 12-05-2011, 02:41 AM
  3. Replies: 39
    Last Post: 05-25-2011, 06:14 PM
  4. Avid Juicy 3.5 160mm to 203mm rotor
    By XAP72 in forum Brake Time
    Last Post: 01-11-2011, 07:26 AM
  5. 160mm to 203mm conversion???
    By Camdonite in forum Brake Time
    Last Post: 01-04-2011, 09:39 PM
Members who have read this thread: 39
