Results 1 to 9 of 9
Thread: 140mm up front?
    140mm up front?
    i have been using v brakes all this time. I m going to disk up front. I only weigh 130lb and try to keep my XC race bike as light as i can. Can i run 140mm disk up front with a BB7? wouldnt a 140mm still be stronger than V brakes?
    first of all, idk what fork accepts a 140mm rotor. Also, 160mm rotor is the standard minimum up front, I think, and barely heavier than 140mm. You will only benefit from increased braking power, provided you have decent braking skill. Don't create a problem where there isn't one, and have fun riding
    break that ironhorse, he he...
    Jul 2003
    As nepernesu noted, I am not aware of any MTB fork that will work with a 140mm rotor. All MTB forks with post style direct mounts are sized for a 160mm rotor minimum, with the exception of some down hill forks which start at 180 and go up from there. And no one I know makes a 140mm IS adapter for IS mount forks. For the front I'm afraid that your pretty much stuck with a 160mm rotor.
    Good Dirt
    160 is fine. I was just trying to see what my option are.
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    Its about a 15g difference between 140-160. I had the same thought process and went with 160 but now im debating goin 180.
    Sheepo
    Raised in a Chicken-Coop by Chickens
    Reputation: Joules's Avatar
    If you care about weight at all (or at least enough to think about using a mini-rotor), why would you even consider a BB7?
    T.W.O.
    Reputation: mimi1885's Avatar
    I've tried 140mm f/r on my road bike, even that I think it sucked. It does not have crisp response. I'd say stick with 160mm.
    My advice to you is to gain some weight.
    Reputation: cockroach's Avatar
    How about 160 front, 140 rear?
    That's what I run, I like to have more power front than rear, but I don't need any more than 160 front.
    Plus, I like to be a bit different...
