Results 1 to 2 of 2
    Reputation: AZ-X's Avatar
    140mm Rear Rotor for '04 Formula B4 Pro +?
    I was wondering if you coud use a 140mm rear rotor with the new Formula B4 Pro + (B4SL replacements) if I order a front brake/caliper without an adapter and use it on the rear. Would this work as it does with Martas and some other brakes, or am I out of luck?
    I believe that the front brake uses a standard IS mount and the rear uses post-mount mated to a Hayes adapter like Hayes and Avid brakes use. Is this correct?
    Thanks in advance for any info.
    Ole
    Ole is offline
    Quote Originally Posted by AZ-X
    This is correct you can use the IS caliper to get 140 in the rear, and I've done it for many of my customers. But, you don't have to buy a complete caliper, you only need the empty caliper half, as well as a long mounting screw. Should run you around USD50-60 plus work if you don't do it yourself. Prior to 2004, the B4 brakes all came with 140mm in the rear, and the same caliper front and rear.
    Ole (Formula-importer for Norway)
  1. Research help
    By mg5904 in forum Bike and Frame discussion
    Last Post: 04-13-2004, 06:32 PM
  2. Turner 5 Spot & Magura Air Pro Rear Shock?
    By Dirk (UK) in forum Turner
    Last Post: 03-26-2004, 12:03 PM
  3. Replies: 0
    Last Post: 03-25-2004, 09:01 AM
  4. Replies: 11
    Last Post: 03-25-2004, 07:50 AM
  5. 140mm rear disc rotor?
    By top_ring in forum Brake Time
    Last Post: 02-17-2004, 06:36 PM
