Results 1 to 3 of 3
    140 mm rear rotor for XTR 965 ?
    Hi all,
    Ok, I stuffed up with a parts order and have ended up with 2 160mm front calipers with IS mounts.
    Am I correct in thinking I should be able to use these 2 XTR 965 front calipers on one bike, but it will need a 160 mm front rotor and 140 mm rear rotor ?
    Is there any further imcompatibility I need to know about ?
    Thanks,
    Timbat
    timbat
    Meh.
    Reputation: XSL_WiLL's Avatar
    Yup. The 160mm front caliper will fit the rear with a 140mm rotor. You can also fit a +20mm adapter.
    DGB
    DGB is offline
    Yep, similar to one of these adapters
