Results 1 to 2 of 2
    Live Free or Ride!
    Reputation: GiantMartin's Avatar
    09 Marta SL vs 08 Marta SL
    The 08 SL's came with carbon levers, but I've been looking @ the 09's and they all say an aluminum lever, even the fancy Ti SL's. What up with that??? Or am I getting wrong info...
    2007 Giant Anthem 1
    2009 Giant XTC 0
    ups and downs
    Nope they're carbon http://www.magura.com/7thsenseCMS/in...p?id=12934&L=1
    Weight (in grams): from 335 grams/0.73 lbs.onwards (depending on rotor size)
    Brake system: Full hydraulic disc brake, open system with reservoir
    Material brake lever/caliper: Aluminium cold forged
    Deceleration in m/secē according to DIN 79100 (100N handforce): 7,0m/sē (203mm), 6,8m/sē (180mm), 6,0m/sē (160mm)
    Piston diameter brake lever/caliper: 11/2x22
    Disc diameter: 203mm, 180mm or 160mm (IS 6-holes)
    Centerlock option SL rotor: yes (with Centerlock adaptor)
    Option Ventidisc 6-holes: yes
    Option Ventidisc centerlock: yes
    Hose fitting caliper: 0° (standard), 90° (option)
    Brake pads: organic, 6.1 Performance (standard) and 6.2 Endurance (option)
    Material fitting bolts: steel
    Transmission medium: Non toxic and skin friendly MAGURA Royal Blood mineral oil
    Hose: MAGURA Disc Tube, easily shortened
    Pad wear adjustment: automatic
    Lever blade: Carbon
    Colour brake lever/lever blade/caliper: red or silver anodized
