Results 1 to 2 of 2
    Oct 2014
    Rear axle DC12 E-thru Tune.
    Hello.
    I am owner of a BMC TE01 hardtail 2015 frame and would like to know if I can put the rear wheel axle?
    This bike wears 10 * 135 and i have wheels 12 * 142 DT Swiss XR 1501, the Tune says that axle E-thru DC12 with adapter his doing for this frame.
    Nobody knows?
    Has anyone tried it?
    Reputation: RobertAxle142's Avatar
    Mar 2013
    Mskaros,
    The frame determines is you are able to change your rear 10mm quick-release to a 12 thru-axle. It appears from the BMC website that the dropouts on the current model frame are not replaceable. Many companies do offer replaceable dropouts so that they can accept a thru-axle, BMC does not appear to.
    I am basing this info off the photo and information on their website:
    Teamelite TE01 29 Frameset - Mountainbike ? BMC swiss cycling technology
    BMC frames that do accept 12mm thru-axles use the Shimano "E-thru" axles. We make axles that are compatible with 12mm thru-axle BMC's so people can use them with their trailers or on resistance trainers. They will fit only BMC frames designed for thru-axles, which yours appears not to be.
  1. Paid Spam: Tune DC15 15mm Thu Axle for Sale (Fox)
    By Tyrone Shoelaces in forum Weight Weenies
    Last Post: 09-17-2014, 03:23 PM
  2. Change axle on tune prince hub! How to do?
    By sivan in forum Wheels and Tires
    Last Post: 03-26-2014, 03:12 PM
  3. Tune princess axle
    By FredrikH in forum Wheels and Tires
    Last Post: 04-17-2013, 08:00 AM
  4. Stripped axle bolt on Tune hub
    By LUW in forum Cannondale
    Last Post: 02-19-2013, 11:24 PM
  5. Replies: 1
    Last Post: 05-24-2012, 01:34 PM
