• 11-15-2012
    atekt
    Great looking bike! I have been loving mine!
  • 12-11-2012
    pat@bike.orbea
    10 Attachment(s)
  • 01-07-2013
    bmcslt01
    Here is mine. Will put up some better photos later.
  • 01-07-2013
    everything motorcycl
    gotta tell ya...i'm still on this post...these bmc are SICK! No regrets with my Spesh comp carbon EVOr...as it is everything I need...but man, love these BMCs!
  • 01-13-2013
    WebInt
    3 Attachment(s)
    Here is my build. BMC makes the best bike I have ever owned.
    XX1, Magura MT8s, Syntace bar/stem, Roval wheels, SID Brain fork. 20.4 pounds.
  • 01-15-2013
    bmcslt01
    More Photos and changes I made
    Here are some better photos and a list of changes I made.
    Quarq power meter
    ESI Grips
    Schalbe RO RO and RA RA
    Roval control sl 29 wheels
    Changed to a type II rearX0 came with type 1
    90 mm stem
    Spec Romin Saddle
    Arundel cages
    Eage beater 3 pedals
    Ritchey bar ends
    Sram gripshift
    Hope Race x2 Brakes
    the rest is from the size Medium stock build.
    weight is 9.84 KG
    Ride report will follow once i have some more seat time.
  • 01-15-2013
    tootall
    Those are gorgeous bikes. More importantly I hear they ride very well. I wish I could have one to complement my FS01.
  • 01-21-2013
    jochribs
    Quarq power meter
    ESI Grips
    90 mm stem
    Spec Romin Saddle
    Arundel cages
    Ritchey bar ends
    Sram gripshift
    Hope Race x2 Brakes
    weight is 9.84 KG
    bmcslt01, can you tell me the measurement from center BB to top of saddle? And that's a medium right? Thanks man.
  • 01-22-2013
    bmcslt01
    72cm
    Its about 72 cm. The frame is a M.
  • 01-23-2013
    jochribs
    Thanks man. This frame is very tempting.
  • 02-16-2013
    NAKaveli
    Sadly, due to needing financial aid I am deciding to put my TE01 up for sale. If anyone is interested lmk, gonna post a ad tomorrow. Still have all parts that came with the bike stock.
    Sz large, currently set up with single chainring, mrp and bionicon chainguides, and tubeless.
    PM for more info/questions
    link to ad:
    BMC TE01 29er size Lrg - Buy and Sell and Review Mountain Bikes and Accessories
  • 03-20-2013
    metalaficionado
    can those be run singlespeed?
  • 03-21-2013
    bmcslt01
    I don't see why not. You would either need to find a magic gear combo/half link setup or run a tensioner.
  • 03-21-2013
    metalaficionado
    i don't see why not. You would either need to find a magic gear combo/half link setup or run a tensioner.
    ok. thanks.
  • 05-14-2013
    laxman2001
    So at 5'8" what size would yall reccomend. I tend to prefer shorter TTs so I was thinking small, but figured I'd ask.
    Everyone still liking theirs?
  • 05-16-2013
    rideronthestorm
    I'm the same height and ride a small. Steering was a bit twitchy with the 70mm stem so I switched it out to a 90mm and it's much more stable. I'll try a 100mm and see how that goes. All around a great bike - climbs well and runs over bumpy stuff with ease. Not as good turning corners then a 26'er, but that might change with bigger tires or playing around with tire pressure. Good luck!
  • 06-15-2013
    ktmrider
    I have te01 frame, and I have problem that derailleur hanger is not aligned with dropout, instead it is a little bit in front. Because of that, my wheel is not centered, it is centered in left for 3-4mm, and when I stand up the tire scratches in frame. Does anybody have the same problem, what is solution for that?
  • 06-17-2013
    bmcslt01
    My hanger and dropout are in line. But I have noticed that if you look at the chain stay clearance. The non drive side seems to have less clearance. I think this is because the stays are asymmetric. The non drive side is thicker and the drive side is thinner where the tire tread passes. At first I thought the rear end was out of alignment or the wheel was not dished properly. But after checking my wheel dish in another frame ,Niner air 9 carbon, it was fine and centered in that frame. This is when I started measuring the bmc and that's where I realized the chain stays were asymmetric. You can also look at the tire alignment with the seat tube this will also help confirm if the wheel is centered. Hope that helps.
  • 06-18-2013
    ktmrider
    Thanks for your help.
    Currently I'm waiting for new hangers, I hope that will solve the problem.
  • 06-18-2013
    bmcslt01
    did bmc acknowledge an issue with it? Let me know how it goes.
  • 06-18-2013
    ktmrider
    Our dealer said that first we will change hanger, and then we will contact bmc, if it won't be ok.
  • 07-10-2013
    bmcslt01
    hey ktmrider,
    did you get the new hanger?
  • 07-16-2013
    ktmrider
    Yes, I install it carefully, an it is ok!
  • 07-16-2013
    bmcslt01
    that's good to hear. Could you post a pic of how the hanger is different? and the tire clearance at the chain stay when you have some time?
  • 07-19-2013
    ktmrider
    I will, soon.
