Results 1 to 5 of 5
    May 2010
    My new BMC SpeedFox 01
    Cranks: FSA V Drive, single speed crank with bash ring, 32-tooth sprocket, outboard bottom bracket bearing
    Group: Shimano Deore 9-speed shifter set and Deore rear Derailleur
    Brakes: Avid BB7 mechanical disk brake (cable actuated) 160 mm rotors
    Brake levers: Avid FR5
    Cassette: Shimano LX 11-32
    Headset: FSA Integrated sealed bearing ZS-3
    Fork: Fox Talas RLC 80-120mm travel adjustment (rebound, lockout, compression, threshold)
    Bottom Bracket: FSA mega XO outboard bearing
    Seat: Fizik Aliante Sport Grey
    Seat Post: Easton EA50 setback
    Wheels: Mavic Crossland rim and disk brake compatible (tubeless compatible)
    Tires: WTB MotoRaptor 26 x 2.0
    Pedals: Specialized flat BMX platform
    Chain: Sram PC 991
    Bottle cages: Cussi elites
    Handle bar stem: Race Face deuce 10 degree x 110 mm, 26.0 clamp
    Handle bar: Answer Hyperlite carbon flat bar
    Grips: Oury grips
    Fast and tooo much Fun. in a couple simple words.
    Now..a few concerns. I transfered all these parts from a Large 19 BMC TeamElite01 and had it professionally assembled at a local bike shop. They did a great job..but since the parts are a few years old i didn't know what to upgrade.
    When shifting it skips from time to time. and it clicks for 2 min then finally shifts to smallest cog. and for the largest cog..it ticks constantly.
    Will a 10spd fit? need a larger big cog for climbing.
    When i turn it seems like my rear brake ( 185 rotor) scraps against something.
    Vintage Hardtail Rider
    Nice Ride !
    I picked up a 2010 Speedfox frame from Competitive Cycles and will start pickin up parts as I can fine em on sale
    May 2010
    Appreciate! Im semi- ''overhaulin'' it this winter with BIGGER tires, full switch to 1x10 (new COG, rear deraileur, shifter), and Hydro brakes. Let the bargain hunting begain!
    Nov 2006
    Shock size?
    Quote Originally Posted by Dparmar3 View Post
    Chain: Sram PC 991
    Grips: Oury grips
    Can you tell me what size shock the 2010 Speedfox takes? I bought a frame without the shock and need to purchase one?
    Thanks.
    Fox RP2
    Hey, I'm guessing that your wondering about the rear shock as some call the forks shocks as well ? Mine has a Fox RP2 and is marked 225. In MM seems right at 8.8" overall length with a center to center (mounting bolts) of 7 7/8" installed in the frame. Hope that helps ya, and enjoy you new ride...
    Quote Originally Posted by chainlink71 View Post
    Thanks.
  1. 2010 speedfox 01
    By bcf811 in forum BMC
    Last Post: 07-12-2012, 02:52 PM
  2. Is the SpeedFox xc race worthy?
    By cartroid in forum BMC
    Last Post: 06-14-2011, 12:48 PM
  3. 2010 Speedfox thoughts and help.....
    By unicron in forum BMC
    Last Post: 01-20-2011, 06:54 PM
  4. BMC Speedfox
    By Dictatorsaurus in forum BMC
    Last Post: 10-05-2010, 04:50 AM
  5. BMC Speedfox vs. Yeti ASR-5
    By Danish Dynamite in forum BMC
    Last Post: 10-03-2010, 11:46 AM
