Results 1 to 3 of 3
    Feb 2010
    Longer fork on Fourstroke?
    Hi!
    I would like to replace my stock 100mm Fox fork with 120mm Manitou Tower. This will rise the front end by 30mm (Tower has 10mm larger axle to crown distance than Fox).
    Do you think that would still be okay? Or will the handling suffer too much?
    Jul 2013
    Given that BMC spec's a 120mm on the FS trailcrew versions, you should be good to go.
    Not sure about the offset specs though.
    Feb 2010
    The Trailcrew versions made me think about this conversion. I'm just worried about the extra 10mm that Manitou forks have over Fox forks in crown to axle distance.
    Manitou also has 3mm smaller offset (51mm vs 48mm). That would further slow down the steering?
  1. Longer travel fork accomodation
    By showtym69 in forum Beginner's Corner
    Last Post: 06-04-2015, 12:27 PM
  2. Has anyone tried a longer fork on a Flux 3.0?
    By Bondseye in forum Turner
    Last Post: 04-22-2014, 07:58 PM
  3. what fork company makes longer fork tubes??
    By 4psnu in forum Shocks and Suspension
    Last Post: 07-09-2012, 11:41 PM
  4. what happens if i use a longer travel fork?
    By vqdriver in forum Shocks and Suspension
    Last Post: 12-08-2011, 12:45 AM
  5. Longer Travel Fork
    By Prostreet513 in forum Shocks and Suspension
    Last Post: 01-21-2011, 12:08 PM
