Results 1 to 29 of 29
    Aug 2005
    Hardtail to BMC Trailfox???
    So there's a pretty slammin deal for a BMC trailfox 1 and 2 on Jenson right now and it's got me wondering if it's finally time to go full suspension. Right now I'm sitting on a 19" 99 Schwinn Homegrown pro that I have slowly upgraded over the years. It has a Rockshox reba team fork, 819 tubeless on hope bulb hubs, hope mini brakes. I got a shorter stem which helped make the cockpit less sprawled out (I'm about 6'). Everything else is largely the same original stuff.
    I've come to really enjoy my bike as it is but living in an area that has some really rocky terrain, I often really want some rear suspension travel. If I got the frame, I'd try to use as much of my current bike's components as possible. I'd like to know
    if the front dehraileur on my bike is compatible as the add says, "high clamp 35.0mm front derailleur"... whatever that means. I may additionally need a larger seat post as my current seat post is the skinnier of the two that seem to be on the market. One of my other many questions is, how stupid am I for recycling all of my old old parts?
    additionally, there's the 1.0 and the 2.0. From what recall, the only difference is one has a better shock. Is it really worth an extra $300 +?? ... I do like the green color though!
    I also may need a new BB as my original may not fit.
    by doing this, would I go from having a relatively light weight bike to a 30+ lb beast? If the answer is, kinda, would it be worth it?
    As far as sizing goes, would I go w/the 19"?? I don't know what inseam has to do with it, but I have a 32" inseam.
    Thanks for your help!
    Reputation: Joules's Avatar
    front derailleur: 35mm is the clamp diameter, 'high clamp' is a conventional derailleur, not a 'top swing.' Most modern derailleurs are 35mm with shims to get down to other sizes.
    seatpost: there are a LOT more than 2 common sizes. Jenson's Zion (house brand) post fits, and is pretty nice for $5. IMO if you are going to spend more than that, get a thomson.
    Definitely not stupid for reusing parts. Most of what I have on my superstroke is cannibalized from other bikes. I doubt you'll be very happy with a reba on that frame though. Some rebas went up to 115mm travel - the very low end of what I'd consider on a bike like that, some years it only went to 100 unless it was U-turn. If it were me, I'd be looking for 140... and IMO pike is the winner in that travel range. That would mean getting a new front hub though (not a bad upgrade, you really want a T/A in that travel range).
    The suspension will change the ride so much, I wouldn't be surprised if you don't directly notice the weight difference, which will probably be smaller than you think. My XC bike is a hare over 20#, superstroke is around 36, between the suspension and the steering geo I hardly notice the weight differences when I go back and forth.
    If the only difference between those is the shock, I'd go with the cheaper; I don't know that it's the only difference though. My superstroke bobs, it needs the pro-pedal on most of the time (but the RP2 it came with is the 'light' PP setting, which takes care of it). I'm leery of DT shocks - seems like weight was the main focus of their design. I wouldn't pay more for a DT.
    sizing... can't answer that.
    Aug 2005
    But that's been my latest upgrade... I read a review where BMC's fully built trailfox 01 has a ride height adjustable fork that goes from 140 down to 100mm for climbing. I have the team that can be adjusted from 85 to 115. In order to get all of the benifits out of the trailfox, if I had to upgrade the fork, that would be another 4-5 hundred beans I would have to spend. You don't think I could get away with my reba for a year or so before upgrading? Would it throw off the geometry?
    ... my hope front hub has that axle conversion as well.... I dunno if that would work with the pike...
    I've been pretty satisfied with my current bike for the longest time that I've been kinda outta the loop with improvements they've made with bikes over the years. Has it really gotten to the point where even a 30+ lb bike can feel light when climbing?
    I'll have to call up Jenson and ask them about the differences between the frames. Some reviews I've read bashed the Ario 2.2, but having never owned a full suspension, I might not know the difference.
    too short a fork isn't going to void the warranty or anything, I just said I doubt you'll be happy with it. Lower A/C than the frame was designed for makes the head angle steeper which speeds up handling and reduces stability. That's great on a climb when you are going really slow - that's when you'd use the 100mm setting on the travel adjust fork. When the trail turns down a slacker, slower steering, more stable ride is what you [generally] want so you can take advantage of the suspension - you can get that with a longer fork.
    Your reba will work, it's just at the low end of travel - I'd guess you'd enjoy something with a bit more. Pike's maxle is compatible with any 20mm t/a, such as your hope hub, so good news there. I'd definitely get the cheaper frame and put the extra money into a fork fund.
    for me at least it isn't that the bike feels lighter than it is, it's that there are so many other differences that I don't focus on the weight. IOW It doesn't feel like taking my XC bike and strapping 15# of weight to it. It's still a matter of horses for courses; I don't think I'd ever use the superstroke in an XC race no matter how rough it was (in my experience XC racing is primarily about how fast you can climb, and nothing I've ever ridden can touch my ARC in that respect). It's just fun/different to ride.
    Aug 2005
    (I didn't see the two posts above prior to writing this)
    Thanks for the info. I should soo just drop the cash on that frame, but I doubt I'm gonna. I was hoping someone was going to say, DOOO it!!! and really convince me that it was worth it. But at the same time, I'm not, because 7 c notes is a good chunk of change. And to make it worth it, I'd need that extra 400 beans for another new fork.
    Just out of curiosity, any idea how much my bike weigh being full XT (from 99) with the 819 tubeless, hope bulb, hope monos, and easton XC stem, riser, and post???
    Oct 2007
    Quote Originally Posted by Joules
    good thing hes looking at trailfoxes and not superstrokes then!
    the trailfox would be perfect with a reba at 115mm.. probably even 100 is fine. everything that guy said was about superstrokes, not the trailfox you're looking at.
    Get your freak on!
    The TrailFox 01 has the better rear shock (much better), but the main reason for the price difference is the 01 has a Carbon rear end, it saves just over 100grams while not taking away any strength or stiffness. If the difference in price is not great, I'd go the TrailFox 01.
    Here is one I bought and built for my farther a while ago.
    Quote Originally Posted by tomsmoto
    no, actually it's not. try learning to read.
    per jenson, about the trailfox: "BMC suggest a fork in the 110-140mm travel range to complement your new frame. "
    I doubt anyone would be happy with the geo at the low end of that, at least not anyone that knows anything about mountain biking.
    Aug 2005
    Joules, I know you were referencing the Superstroke since it is another BMC product. Maybe Tomsmoto didn't get it. Eitherway, Thanks both of you for your input.
    bike_freak, that's one sexay bike! The dude I talked to at Jenson was quick to state his opinion that the 01 is easliy worth an extra $300 for a bike that didn't have anything extra other than a better shock. He did not know that the rear was made using carbon fiber.
    The White Jeff W
    Reputation: jeffw-13's Avatar
    No moss...
    Oct 2007
    im just saying.. bmc says its fine to run the bike at 110mm-140mm.. so the reba at 115 puts you well in the clear. its not like its going to ride like ass because you're not running at the edge of the spec at 140. if you want to upgrade the fork later, hey great.. but you could ride it all day long just swapping your parts over.. you'd have a great spec'd bike that rides well within its intended range.
    Aug 2005
    jeffw-13, looks pretty sweet. 30lbs is pretty lite for a 5" travel bike, right? The 7th pic down shows your crank and BB. Does the frame require a special BB and or cranks?
    that's what I was hoping.
    Reputation: MMcG's Avatar
    Jul 2003
    what is the HT angle on those bikes even with the 5 inch or 5 inch plus forks? They look almost Cross Country like with steep head tube angles - is this accurate?
    The White Jeff W
    Quote Originally Posted by SoobieNeil
    Not my bike. I just think it's sexy.
    No moss...
    I would stay away from BMC. They don't have a good rep in MTB, even here in the EU.
    Aug 2005
    by reputation, do you mean with warranty claims or craftmenship/quality?
    Mar 2005
    Quote Originally Posted by Jerk_Chicken
    I have had a TF02 now for a few months. My other bike is a '05 yeti 575 - so I have a pretty good yardstick to judge it by.
    The Trailfox 02 frame is definitely laterally stiffer than the Yeti and it is also a more
    efficient peddler. The handling is a bit different, the Yeti being a bit slower and more suited
    to fast down hill type riding. Having said that, the more I ride the TF the more I like it.
    Jason English won the Australian 24hr solo championships on a TF01, so this bike can
    certainly be raced XC if you want to.
    Overall, it's a great bike and very fast once you get to know it. I would also go for the TF01
    as the only complaint I have is with the rear shock. I'll be replacing the stock DT at some
    stage.
    cheers
    TCD
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    Quote Originally Posted by MMcG
    It does look pretty steep for a 140mm bike...
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
    Aug 2005
    The head angle is 69 degrees according to BMC's website. ...dunno if that's steeper than usual.
    stage.
    You mean RockShox, right?
    Smile How does it ride?
    Quote Originally Posted by bike_freak
    Nice bike, are you running a Fox Talas fork? How does the bike ride at 140mm(5.5 inch) of travel? Or is it better offf with the 120mm ( 5 inch).
    Would you say it is a XC bike or a trail bike
    Some photos of the bike look way steep with the head angle, your bike in the photo looks ok. Do you know the HA for the 2007 model?
    Get your freak on!
    Quote Originally Posted by chompychay
    The fork is actually the Trail Tune (terralogic), I think it is a 2006 fork? The fork has 130mm of travel and I believe it suits the frame really well. As for recommended travel of the fork, i'd say it depends on what you want out of the bike, 115-120 is ideal for XC/Enduro riding and the bike is quick at the length, a 140mm fork works well but will make standover an issue in some cases and maybe the bike wander a bit on the climbs. I personally think a 120mm length fork is perfect for this frame.
    I'm not sure on the head angle of this bike, I'm pretty sure with a 140mm fork it would be roughly 69 degree, not super slack but this is a all day endurance bike after all and it pedals very well.
    Reputation: thing's Avatar
    Oct 2007
    I don't think you know what your talking about I have an 02 and I love it.
    I went from a Specialized Rockhopper to a BMC TF02 and love it!
    No bob while seated, minimal while standing. An absolute blast to ride.
    Aug 2005
    I ended up going with a brand new complete Rocky Mountain. When I went to a store that carried the TF02, the stand over height was really high. I forget if it was a small or medium sized frame. I'm 5'11" so I normally ride a medium. Standing flat footed, I had almost no room between the top tube and the family jewels. I ended up taking demoing a Fuji Reveal 2.0 and a Specialized FSR Elite. Both bikes were considerably heavier than my Schwinn so when it came to climbing, I was much more winded when I got to the top of some hills. Downhills were a LOT more fun however. I wasn't able to get the Reveal setup correctly but absolulty loved the new XT stuff that is on it. As well as the seemingly bottomless suspension. The FSR rode harsher but climbed like a mountain goat and had even better components than the Reveal (X0 is money!). But was also an extra $1.5k more... Too rich for me. So aside from the stand over height, I realized that buying the frame just wouldn't be the same experience as having a whole new bike w/all updated equipment. Sure it would have been about half what I spent on the new bike, but it would have been like putting an old transmission and interior in a new car. Plus I think the extra coin I spent got me lighter stuff (about 2 lbs lighter) than I would have been had I gone with the BMC frame and to me, weight really does matter. I don't want this to discourage anyone from going with the BMC. Aside from the stand over height, it felt right... at least in the parking lot. I do think you should at least sit on one before you buy a frame.
    Hmm .. is this bike with the carbon rear triangle a safe bike then ? Wouldn't the carbon fail over time ??
    Reputation: qdawgg's Avatar
    I'm looking at a 2009 trailfox 02 - not just the frame but a complete bike from BMC. Would anyone who owns a 2009 mind giving me a little feedback/impressions on how the bike handles for normal cross country trail riding. What I'm most worried about is the head tube angle being 69 degrees. My current bike (santa cruz superlight) has a 71 degree head tube angle but I also know that all the specs together can make a big difference. Thanks for any input.
    I have a 2009 TF01, it has 140mm and 68deg instead of 120mm and 69deg. The TF02, you're looking at is renamed to Speedfox for 2010 (which makes sense as at least now the amount of suspension is coupled to a particular name). The Speedfox had a few reviews recently in german bike magazines and was generally regarded as an excellent bike with superb suspension design. For a trail bike 69deg is generally much nicer than 71deg, unless your surroundings exist of mostly slow-speed tight turn kind of trails. What I can say is that the TF01 is one excellent bike, I felt immediately at home on it, suspension is fantastic and I leave propedal off permanently.
    Live Free & Ride
    Reputation: NH Mtbiker's Avatar
    I just built up a 2008 TF01 and just love the way it rides! Had it on the trail early this morning and decided to lock-out the rear shock (DT XM180) on some hills. The bike just climbs like a goat when locked and I cleared a section I rarely did on my hardtail 26" Caffeine bike. I am also running the X-Fusion Velvet at 130mm with a 15mm thru and it seems perfect. I decided to go 2x10 SRAM at 26/39, and I must say, it is spot on for trail riding, no problems at all.
    Attached Thumbnails Attached Thumbnails Hardtail to BMC Trailfox???-summer-july2-010.jpg
    14 GT Zaskar 9r
    15 Moto Night Train
    08 BMC Trailfox
    06 Cannondale Rush
    99 GT XCR
    93 Raleigh MT 200
    i ve got reba 115 ( or 120 mm ) with trailfox 02 2009. Geo is ok, but i would prefer fork like talas 140mm
