Results 1 to 3 of 3
    Reputation: parkp81's Avatar
    BMC Trailfox Owners - Shock Hardware Clarification
    I've tried searching and was able to find out the shock size that I need if I were going to replace my 07 Trailfox Rockshox Ario 2.2 shock. Which is 200mm x 55mm for DT Swiss XM 180 and Fox RP2/RP23, 200mm x 50mm.
    The part I am stuck at is the shock hardware, there are so many sizes and I could not find the answers to what size bushings I need. I've also read that it should come with the shock, but if I am buying one that does not have the necessary bushings, I will need to somehow obtain them, thus I am asking for your help.
    Thank You
    Ask the guy in this post since he found the size for his 07 Trailfox 02 : 07 trailfox 02 rear shock mounting hardware
    I actually did ask him, after I found his thread. =)
