Results 1 to 5 of 5
Thread: BMC Trailfox 02
    Feb 2010
    BMC Trailfox 02
    Does anyone have this frame? I wanted to know what size QR I will need becuase the frame is on order and I just realized I might need a new wheel.
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    Is this what you're asking?
    Rear wheel: 135mm dropout to dropout spacing and usually a 10mm axle.
    Front: depends on the fork
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    Feb 2010
    So a 9mm qr rear wheel won't work? It has to be 10mm?
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Quote Originally Posted by Bloober
    9 mm for the front , 10 mm for the rear . 10 mm is the accepted standard .
    Reputation: Slurry's Avatar
    Dec 2008
    all modern rear wheels use a 10mm axle, or an axle that reduces to 10mm at the dropouts. the diameter of the quick release (and the hole that goes through the axle) is pretty much the same on both the front and rear wheel.
