Results 1 to 13 of 13
    Keep Riding !!
    Reputation: AussieRider's Avatar
    BMC Team Elite 01 - 7.7 Kg / 17 lbs
    Here's a new BMC Fully Rigid at 7.7 kg
    Frame: Team Elite 01 (full Carbon)
    Forks: Pace Carbon Ti
    RD: Sram XO
    Shifters: Sram XO Grips
    Nokon Cables
    FD: XTR
    Brakes: Avid Juicy Ultimates - Hope Rotors
    Wheelset: Stans ZTR Race, Tune Prince/Princess, Marwi Ti spokes, Alloy nipples
    Cranks: Token
    Bars & Post: Easton
    Grips: Oury (cut down for grip shifters)
    Pedals: Ritchy WCS
    Saddle: SLR
    Zip Bottle Cage
    Just Ride !
    Reputation: Broccoli's Avatar
    What is the weight of fork and of the rotors?
    Reputation: Tiffster's Avatar
    Whats the rocket ron/furious fred combo like i was going to try that myself ?
    What's "social pace?"
    Very, very nicely done.
    I have that same fork coming in the mail.
    ♥ ς╥33
    Reputation: longcat's Avatar
    How does it ride?
    Quote Originally Posted by Curmy
    Carbon is a fad.
    Quote Originally Posted by robicycle
    Just lube your ass with asscream and ride for how long you want.
    Reputation: 743power's Avatar
    whats the weight of that frame? that would be a sick bike for me with a new sid team, would come in around 18.5lbs.
    Hack Racer
    Reputation: Cheers!'s Avatar
    Nice build. How heavy is the frame? WIth those parts I would've thought you could pull off 17 lbs w/ a suspension fork...
    Hack Racer
    double post...
    Keep Riding !!
    Quote Originally Posted by Cheers!
    Thanks for the comments
    Bike was built as a reliable & strong dirt crit racer (no need for a susp fork) with fairly standard parts, sure could make it lighter but would mean even more $$$
    Frame is not super light at about 1.4kg but is stiff and strong, Pace forks are around 700gm (maybe less), no idea of weight of the rotors
    Rocket Ron/Furious Fred combo works well for intended use, and being a stiff frame accelerates like a rocket but also has the compliance of carbon
    Just Ride !
    Jan 2009
    As the builder and rider of the above bike i can say it is a pleasure to ride. the forks are 420mm long so it steers very quickly. tyre combo is very fast an light. it must be said that the rear tyre has no grip in a straight line but once you lean it over it is fine. The trained eye will note the Easton Road seat post and carbon headset cap from Pro Machine, Ritchey WCS stem (logos removed) and small touches like the upper and lower head set cups are not the same, lower one is deeper (fitted with alloy crown race) to lower the front even further. The factory seat clamp is fitted with Ti bolts. XO rear gear is short cage with 12-27 tooth Dura-Ace road cassette. Token crankset is fitted with alloy chain ring studs and has had both the plastic centre sleve and the cup spacers removed from the BB the chain line has been improved with custom machined alloy spacers on the spindle. It is not the lightest frame as stated above but super quick and can still be trail ridden. when not racing it wears 2.25 and 2.4 Racing Ralph tyres.The forks are 646g cut and the rotors are about 90g each.
    I think the frame was about 1.45lkg
    Kaos Captain ( Bike technician kaos Custom Bikes)
    Note: we do sell
    BMC bikes but not sponsored. This is a personal bike and is not for sale.
    Reputation: Cranked's Avatar
    Awesome wheelset, what did you use to tie the spokes? Do you know what the wheels weight in at alone?
    Jan 2009
    The binding is plastic coated copper wire for winding electric motors and transformers.
    The wheels weigh 1125g for the pair.
    Very jealous!
