Results 1 to 2 of 2
    2016 Speedfox Trailcrew 02 - Swap 150mm to 160mm fork?
    Curious if anyone has tried this. The numbers on the speedfox are very similar to the Evil Insurgent: The Insurgent | Evil Bikes
    Nov 2013
    This sub forum doesn't get much action at all. From what most bikes will take an extra 10mm no problem. Be sure your fork doesn't already have a spacer in it you can remove some are spaced down when shipped for exact bike. Consider if you use 30% sag it will be riding with 3mm more sag anyway . Trailcrew is already stretched out already ,stretching. it out much more won,t make it into a downhill or all mountain bike.So be careful not to break an amazing bike using it for such.
  1. BMC Speedfox 02 Trailcrew
    By madamfunk in forum BMC
    Last Post: 11-08-2015, 08:22 PM
  2. Which 2016 Fork? 160mm Pike or 160mm Lyric for 650b
    By JNG in forum Shocks and Suspension
    Last Post: 09-07-2015, 11:36 AM
  3. Pike 150mm/160mm steerer swap question
    By dromond in forum Shocks and Suspension
    Last Post: 06-29-2015, 04:01 AM
  4. 150mm or 160mm fork on the SB66?
    By Crash-VR in forum Yeti
    Last Post: 01-28-2014, 08:11 PM
  5. EG V2 Fork Swap 150mm to 170mm
    By Yorkshirepadd in forum Titus
    Last Post: 01-17-2013, 03:42 AM
