Results 1 to 10 of 10
    2010 trailfox questions and geometry
    Anyone know where to find the specs on an older trailfox? I can't seem to find any archives for the geometry. I see a few used ones I would like to buy but here isn't any local I can demo or ride. Does anyone have the geometry specs for a small trailfox or know of a bike with the same geometry? Are these good all mountain bikes? Where I ride it isn't flat so a lot of fire road climbing with fast and steep descent.
    Get your freak on!
    I have the stats for the 2009 Trailfox 01, which from memory is the same frame.
    Small size:
    Effective Top Tube: 565mm
    Seat tube: 420mm
    Headtube length: 125mm
    Head Angle: 68 degrees
    Seat tube angle: 73 degrees
    Rear chainstay length: 433mm
    Wheelbase: 1100
    I'd say the bike is a brilliant trail bike, pending on your idea of All mountain; it may not offer enough travel.
    Well... I don't do ramped jumps or drops over 3 feet so me asking for all mountain is probably not warranted.
    Shh, don't tell anyone where you got this.
    Attached Thumbnails Attached Thumbnails 2010 trailfox questions and geometry-bmc_capture.jpg
    oh, and I believe the 09 has less travel. 130mm vrs 140 I believe. 2010 also uses a standard bearing size.
    If you go to the bmc website, go to the "bikes" pulldown, Bikes 2010
    It has an archive of all their 2010 bikes including both the trailfoxs
    Hi,
    I've just bought a mint 2009 Trailfox TF02 size M frame and I'm going to build it into a trail bike for my brother. I'm not getting any response from BMC about the specifications, though.
    Am I correct to assume, that the geometry for their 2009 and 2010 bikes is the same?
    Also, if someone could look up their bike manual and tell me what the recommended rear shock dimensions are (ETE, stroke) that would be super helpful. Is there any tolearance, or must it be spot on?
    I'm thinking 200x57 mm (or 7.875x2.25), according to the shock chart at enduroforksealsDOTcom (sorry, can't post link).
    Thank you very much for any answers,
    Matevz
    Deleted
    Delete
    To answer my own question:
    Kinetics/ shock absorber BMC TF02 2009
    - Rear shock = FOX RP-2 with Pro Pedal & rebound adjust
    - Shock length = 200mm
    - Compression travel = 57mm
    - Shock width top end / bottom = 22.20mm
    - Shock installation bolts top / bottom = 8mm
    Thank you kind LBS, no thanks to BMC (infoATbmc-racingDOTcom), five mails in three weeks go unanswered.
  1. 2010 Trailfox TF02..what to expect?
    By Chase1996 in forum BMC
    Last Post: 08-30-2011, 09:07 AM
  2. 2010 GT Sensor 9r Geometry
    By JAHAMMER in forum GT
    Last Post: 12-28-2010, 12:05 PM
  3. 2010 Stumpjumper FSR Geometry/ Med or Large?
    By alshead in forum Specialized
    Last Post: 08-06-2010, 12:04 PM
  4. 2008 vs. 2010 Fuel EX 9 geometry
    By NashvilleBlur in forum Trek
    Last Post: 11-15-2009, 11:02 PM
  5. 2010 Enduro Geometry
    By goingleft in forum Specialized
    Last Post: 10-25-2009, 09:13 AM
