Water filtration vs Water purification
What are you guys experiences with water filters and water purification?
More specifically, I'm looking to get something that can give me clean(enough) water quickly. So I'm not really looking into pills that will take 4 hours, or even 30 minutes. Mostly I'm looking into some of the smaller water filters like the MSR Sweetwater microfilter and the Katadyn Hiker Pro vs a Steripen of some sort.
I ride in the South-East. At this point, all of my bikepacking trips have been in Florida. I don't think viruses are a huge problem here. Aside from springfed rivers, most of our rivers are tannic.
How do the steripens handle tannic water? Waters clear, but red... Does that affect how affective the UV lights work?
Do the tannins in the water clog the filters on the MSRs and Katadyn filters?
What about if I'm riding nearer to the coast. Some of these freshwater rivers run into the gulf and ebb and flow with the tides... you can catch marine fish several miles upstream. I can only assume there's some saltwater influence in these creeks and rivers. Do the steripens(doubtfull, but I'll ask) and water filter systems deal with salinity at all?
I've asked a couple outdoor shops about the tannins and salinity, and they had zero input. Both shops leaned toward filters, but one leaned towards MSR(did not carry Katadyn) due to it being servicable and reliable. The other shop leaned towards Katadyn(and carried both brands) due to it being a much simpler design and more reliable than the MSR. It seems the MSR will filter out smaller particles though...
Anyway, thanks for any help
If you get a filter that is offering adequately high pressure, you get freshwater pretty much no matter what you start out with.
4 bar is a good starting point.
I have no clue as to how to press the water through though, as my knowledge come from using reverse osmosis in the medical field.
Magura
Sweatwater's work great and if you need to filter water out of a murky steam to remove fines, add the pre-filter.
To avoid carrying an extra peive of gear, consider this hydration pack with the added inline filter.
Amazon.com: Geigerrig G1 1200 Hydration Pack: Sports & Outdoors
Amazon.com: Geigerrig In-Line Water Filter: Automotive
You can fill the bladder from the stream/lake and the inline filter cleans the water before you drink it. The pressurized bladder rocks too and can be helpful in cleaning dishes when camping or spraying out wounds if you crash.
I don't believe any backpacking filter will remove salt. That requires a distillation process.
Cloudy water will reduce a steripens ability to mess with the bugs reproductive systems.
The bugs are still alive they just can't have baby bugs and it does nothing for clarity.
Yum protein in my water.
If you want your water to be clear and taste good the MSR mini Works is the best I've found but it is also the heaviest.
My backups are tablets yuk and boiling for 3 minutes with a small alky stove,
As a recreational bikepacker one of the things I enjoy is to filter all my water for a given trip.
I like the idea that my water is not filled with chlorine from my city water system.
04 Azonic Saber
08 Yeti AS-x
12 Rocky Mtn 29er Alt 970
A pressure filter sure will remove salt. It's simple osmosis.
I know such filters are available, as I have used them for a different purpose in my lab.
Some are pretty small. I've seen them used for aquariums.
Magura
Everything you ever wanted to know about water filtering and types of filters used in the backcountry.
This is a great read and a site well worth bookmarking.
After spending several days studying this website and scaring myself half to death haha
I settled for the MSR miniWorks.
The quality of my water when bikepacking is very important to me.
It might not be as much for you.
Zen Backpacking - Water Purification, Filtration and Treatment
04 Azonic Saber
08 Yeti AS-x
Your average hiking filter will not desalinate seawater. Reverse osmosis is required and because of the nature of the membranes used, water often has to be pre-treated and may not be useable for freshwater applications as well. There are products that can do that, many used for military applications, but they are rather expensive. This Katadyn "Survivor" costs $900 and process 1.2 gallons/hr.
Amazon.com: Katadyn Survivor 06 Desalinator: Sports & Outdoors
Desalination plants are extremely expensive for municipalities to build and that is why we do not see very many of them. If it were cheap, you can bet Los Angeles wouldn't be pumping water from the Colorado River all the way out there.
If seawater is all one has access to, there is always the simple method of recapturing transpiration using a tarp and collecting that. But as far as a filter and drink on the go, there are not really any affordable seawater purification systems out there.
This type is my favorite. It's a gravity system. Simple, works almost as fast as pumps, and you don't have to do anything. It is subject to clogging but flushing is easy enough and pre-filtering with some cloth has given me no issues. I have the Platypus version, which is the exact same filter but different style bag. I would recommend this one over the Platypus. Using you own bladders/bottles you already have can shave weight too.
MSR Autoflow Gravity Filter | Backcountry.com
In the Northern Rockies i use this system: Mike C's ULTRALIGHT TIPS - treating water - YouTube
Simplest, lightest, smallest, and quickest method I've found to treat clear water.
Lot of great info here. Paramount is knowing your region and what you're up against. I'd like to add my fav to the mix considering we roll on similar terrain(Ga) even though I consider Florida a foreign territory for a number of reasons. Sawyer squeeze is hard to beat in my mind. It can be used as a gravity filter at camp - immediately at the source via included bags - inline using a camelbak - claims 1 million gallons with backwashing - is under $50 - and weighs a scant 3oz.
That said, stick with the conventional wisdom and bring aqua mira as back up. Also, buy from REI so you can return if need be.
Fun fact: Jason Lewis, in his 13 year circumnavigation of the world using only MANPOWER, used the desalinator wahday mentioned above while PEDALING his sea kayakamajig across multiple oceans. Blows my mind every time I reread the story.
Reason: Corrected name of dude thanks to wahday
Wow that's expensive for that.
The filter costs like 50$, add another 20 for a filter housing, and throw in the first and best small pump you can find.
I'd say a real reverse osmosis water filtering gizmo could be made for like 100$.
Magura
Magura
And you're just the guy to do it! That would be a very cool DIY/MYOG undertaking and would have a lot of interest I suspect. I haven't looked around at any DIY filter projects but I find that many of the survivalist websites have some interesting ideas for these kinds of things. That's how I first learned about the beer can alcohol stoves. Some of the discussions of the end of the world are a little too extreme for my taste, but some cool ideas nonetheless.
And just for clarity, I read the article on the guy that pedal-boated around the world. Totally amazing! But Graham Bensinger is the guy who wrote the article and interviewed the traveler, not the guy who circumnavigated the world. The adventurer is named Jason Lewis (a Brit). Credit where credit is due... Thanks for sharing that link - super cool!
+1 for the Sawyer Squeeze. Super-light, pretty much maintenance free, and great flow.
Magura
I'd be interested in making one. I think it would be great to have for the bug out bag.
It would have to be a pretty strong hand pump. High pressure low volume. RO filter membranes are quite small. A very good pre filter to prevent clogging the RO would also need to made.
04 Azonic Saber
08 Yeti AS-x
I'd say anybody could pull that off.
A simple pump, a couple of fittings, a filter and a housing. That ought to be a cosy afternoons work.
Amazon.com: 75 GPD Reverse Osmosis (RO) Membrane (removes fluoride): Home Improvement
Even cheaper than expected.
Those are the filters that millions of households are using.
A nice tried and tested solution.
Magura
Cross posting. See above
Magura
Thank you for the links. That hand pump looks awesome.
I though I would look at the housing this filter was made for and adapt the fitting accordingly.
Add a fishtank foam prefilter and maybe an inline paper filter should allow the RO membrane to last a long time.
I hope the OP is taking notes this is a lot cheaper than 900 Katadyn although it might not be as robust..
04 Azonic Saber
08 Yeti AS-x
I carry a pump filter, used to be Pur Hiker, now Katadyn I think. Backup is Aqua Mira drops.
The filter does many things well. You can pump water from tiny seeps which are too small to dip a pot or cup into. They remove mud. You can pump directly into your water container.
Aqua Mira works well. I go ultralight with just that sometimes. I have to wait for the chemical reaction. I get to drink dirty water. I don't worry about the residue, as I don't drink this stuff all the time. I have to think which water bottle has had dirty water in it, and whether it has been purlfied.
All in all, I prefer to take a pump filter with a tube.
Don't have experience with the MSR filters. Have found the Katadyn Pocket FIlter to be more than sufficient filtering water in nearly all conditions. One aspect that really impressed me was when we had to cross a cedar bog and filter water. The water started a thick murky black and ended up looking similar to a light ice tea tint. If we made a second pass filtering the water I think it would be clearer. Another nice feature is they are all metal with no plastic to break in rough conditions. It is a little on the heavy side but it has been reliable.
Another vote for the Sawyer. I use one with the inline kit and love it. Getting clean water is as easy as filling my bladder and drinking as normal. And it's only 3 ounces! You'd be crazy to get anything else.
Thank you all for the great information, if there's more, keep it coming!
Definately going to get something this Christmas to make my water needs easier(at this point I'm carrying water and planning my trips around resupply points).
The reverse osmosis filter linked above is for super-purifying already-clean and safe water. Desalination requires RO pressures on the order of 1000 PSI, while the linked filter is tested at 65 PSI. (Not even sufficient for brackish water.) Which is mostly moot, because there's no way those hand cranks will get anywhere close to the required pressure. Sometimes things are expensive because there's a conspiracy to keep people from getting the cheap & easy alternative. Other times, things are expensive because they are hard. This is one of the latter. The best you'll get with this solution is equivalent to a $50 backpacking filter, but with greater bulk & weight.
So does this mean we are back to distilling or the $900 buck pump filter to make saltwater drinkable?
Second note: I saw a guy drop his squeeze bag, it hit a boulder and burst open at the seam.
Thank goodness he had a platypus spare bag and the filter fit it as well.
I was really sold on the Geigerrig pressurized bag system after watching the youtube video of the guy throwing one out the window of a car at 90mph and it did not break.
However after less than a year of service one of my bags developed a leak from simple rubbing in my pack. I have since switched back to nalgene bottles.
They have never let me down, some of my bottles are 7 years old, and have seen every abuse from freezing to warping from being to close to the fire to rolling down a hill, dropping, etc.
04 Azonic Saber
08 Yeti AS-x
- You may not post replies
- You may not edit your posts
Forum Rules
