Results 1 to 3 of 3
    Reputation: Aushiker's Avatar
    Trinity Portable Wind Turbine
    Trinity portable wind turbine ... 30 cm in height, 15 watt generator, 15,000-mAh lithium-polymer battery pack and two USB ports.
    The plastic-bodied Trinity is carried as a 12-inch (30.5-cm) cylinder when not in use. When you want to juice it up, you pull out the turbine's three aluminum legs, and prop it up to catch the wind. The legs can be laid flat to form a pedestal, or partially extended to form a tripod base. And yes, it is waterproof (rated to IPX6), should the wind be accompanied by rain.
    As the blades turn, they spin an internal 15-watt generator that in turn charges a 15,000-mAh lithium-polymer battery pack. Using one of two USB ports on the bottom of the unit, you can then plug in your phone (or other device) and charge it. According to Skajaquoda, the Minnesota-based company that's developing the Trinity, one full charge of the battery should allow for four to six phone charges you can also forgo the battery, and charge your phone directly from the generator.
    Source: Gizmag
    Andrew
    Reputation: Skeeno's Avatar
    Jan 2009
    Cool idea, but $400, what?
    There are cheaper options already as listed in the article.
    $50 Versatile HYmini wind and solar portable charger
    This one looked pretty nice, but not available. Orange Wind Generator
    $700 Whaaa? Powertraveller's modular charger powers up by crank, sun, wind and water
    I guess I'll stick with my $15 3200mah portable phone charger
    Dec 2005
    I'd rather just not bring electronic gizmos with me. Camera sure. Phone for emergencies, maybe. Sure wouldn't want to lug around a wind turbine... that's silly. I can think of some applications for something like this, but not backpacking/bikepacking.
  1. Trinity Lake trails
    By abeckstead in forum California - Norcal
    Last Post: 09-01-2012, 10:21 PM
  2. portable air pumps v Big air c02.
    By C.M.S in forum Beginner's Corner
    Last Post: 08-16-2011, 08:31 PM
  3. Trinity Alps - WHOA!!
    By dirt farmer in forum Oregon
    Last Post: 08-16-2011, 04:31 PM
  4. portable washer
    By crazyjeys in forum General Discussion
    Last Post: 06-24-2011, 10:43 AM
  5. S. Fork Trinity River - advice/suggestions?
    By LemurianGuy in forum California - Norcal
    Last Post: 06-10-2011, 09:55 AM
