Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 101 to 125 of 153
  1. #101
    gran jefe
    Quote Originally Posted by eugenemtbing View Post
    This seems like a nice alcohol stove design:
    How To Turn A Beer Can Into The Only Camping Stove You'll Ever Need on Vimeo
    Haven't tried it yet, but will.
    That lit fast and put out a lot of flame! I might have to try that design. Any idea why he drilled the one little hole between the flame outlets and the rim of the can?
  2. #102
    Stoves gone wild
    Must be a vent for air intake?
    I bought and drank a large lemonaid today, in preparation for my stove!
    Got a bottle of ethyl alcohol at the drug store for $2, but wonder if I should have gotten isopropyl/rubbing alcohol.
  3. #103
    gran jefe
    hmm, some kind of vent is prolly right. ah, i think it may be to prevent liquid fuel from being forced out of the burner jets.
    i use HEET from automotive section of bigboxmart. it is methanol. ethanol supposedly burns ok, but isopropyl is supposedly sooty.
  4. #104
    Reputation: Skeeno's Avatar
    Jan 2009
    Just made one. I like it better than the one I made with the jet holes. I like that I can put my pot directly on the can. I used Denatured Alcohol and boiled 2 cups of water in under 6 minutes.
  5. #105
    Stoves gone wild?... how about wild stoves that are historically traditional ... like an open fire.
    Warren.
  6. #106
    Jan 2009
    Campfires are not allowed in my area.
  7. #107
    msr pocket rocket. just remember something for a wind screen.
  8. #108
    Stoves gone wild
    For those who want to live and breathe stove options or, like Vik, just consider themselves stove addicts:
    http://adventuresinstoving.blogspot....n-jim.html?m=1
  9. #109
    Stoves gone wild
    I made a stove as outlined in that video. Started out with 70% ethyl alcohol. Could not keep it burning with the pot directly on the stove. It would burn OK when I spaced the pot above the stove with 1/8th inch brazing rod laid across the face of the stove, but this was unstable and finicky. The flame was blue and clean.
    I then tried HEET (methyl alcohol) and 91% isopropyl alcohol. Both burned well with the pot directly on the stove. It took 8 minutes to boil two cups of cold water with HEET, and 11 minutes with isopropyl alcohol in 60 degree outdoor air temp with very little wind. The HEET burned blue and clean, and the isopropyl burned orange and sooty.
    The clear winner is HEET, but it is clearly poisonous/toxic. I would rather use isopropyl or ethyl alcohol, which are actually sold as a skin antiseptic. Not sure if that is feasible though.
    In the end, I probably screwed up this stove by enlarging the flumes and adding pin holes, etc., so a new one is in order. It is certainly small and light. The flame is not vigorous, however, which makes me wonder if it would be a PITA to use in the wet, windy, stormy conditions many of us bikepack in.
  10. #110
    Feb 2012
    Anybody have any good ideas for improvised windscreens? I'm abroad right now and forgot the windscreen that came with my MSR Whisperlite, although I'm using a Pocket Rocket right now.
    www.julianbender.net
    Pictures of bike trips, hikes, and other travels
  11. #111
    lai
    lai is offline
    Dec 2011
    Quote Originally Posted by Wild Wassa View Post
    Stoves gone wild?... how about wild stoves that are historically traditional ... like an open fire.Warren.
    Always when there is a chance to use open fire I use this military proven mess kit. MILITARÍA 1914
  12. #112
    Jan 2009
    Quote Originally Posted by jbphilly View Post
    I use a sheet of aluminum foil folded over a few times.
  13. #113
    gran jefe
    I use aluminum roof flashing, but that may not be easy to get. if you cut the top and bottom off of an aluminum can, you will end up with a decent little sheet of aluminum to experiment with.
  14. #114
    Feb 2010
    Another option is to make a windscreen from the bottom of an alu baking tray - the disposable type. They are thicker than alu foil and can stand up to a fair amount of abuse.
  15. #115
    Mar 2012
    I also use aluminum foil. The restaurant grade is best (snagged from leftovers), but doubling over the consumer grade works fine as well. I make it so the ends overlap so you can fold them together snugly. I like the disposable baking tray idea as well. The whisperlite screen isn't much more than that to begin with.
  16. #116
    Reputation: random walk's Avatar
    Another vote for the disposable alu pans. But in a pinch the foil is fine. It will burn more easily though when close to the stove flame.
  17. #117
    Reputation: vikb's Avatar
    I had an old beat up MSR stove windscreen I cannibalized to make a smaller screen for my beer can stove.
    It's got a nice blend of stiffness and flexibility.
    Safe riding,
    Vik
    www.vikapproved.com
  18. #118
    If you want to make a conical windscreen / pot stand, in post 34 I provided a link to zenstoves.net on how to make the template using your stove/pot dimensions.
    Once I got the cone (frustrum) dimensions, I laid out some paper on the kitchen island, taped it down, and used a pencil tied to a string of appropriate lengths to draw the arcs. A little additional friggin'ometry calculated where to draw the side boundaries for the desired radii. That was the hardest part of the effort (must remember to include overlap for the interlock, if any).
    After a test fit of the paper template over the stove/pot, I placed it over the bottom of a disposable lasagna pan, traced the outline with a sharpie, then cut with heavy-duty scissors. I punched vent holes every 3/4" or so with a standard paper hole-punch and made a couple of cuts for an integrated interlock.
  19. #119
    Not a choice for "minimalist's", but for those who need (want) to simmer, cook w/ a pan or just want a simple, strong, versitile stove w/ a wide flame and don't mind a few extra ounces, I like the good 'ol Primus Classic Trail (formaly the "Yellowstone"). More often than not, it's "The one that gets used"...
    <a href="http://www.flickr.com/photos/51222326@N04/7544843650/" title="S1190038 by wardee61, on Flickr"><img src="http://farm8.staticflickr.com/7106/7544843650_6930668431.jpg" width="500" height="333" alt="S1190038"></a>
    <a href="http://www.flickr.com/photos/51222326@N04/7544845716/" title="S1190040 by wardee61, on Flickr"><img src="http://farm9.staticflickr.com/8426/7544845716_6fc1d9c4c7.jpg" width="500" height="333" alt="S1190040"></a>
  20. #120
    Feb 2010
    You guys got me all fired up to make one of those stoves as well. I like it! Simpler in operation than the penny stove I normally use and almost instantaneous formation of the jets.
  21. #121
    Always in the wrong gear
    Reputation: Coondog#77's Avatar
    Quote Originally Posted by TigWorld View Post
    Just found a vid on how to make this stove, figured id share.
    <iframe src="//player.vimeo.com/video/64726512" width="500" height="281" frameborder="0" webkitallowfullscreen mozallowfullscreen allowfullscreen></iframe> <p><a href="http://vimeo.com/64726512">How To Turn A Beer Can Into The Only Camping Stove You'll Ever Need</a> from <a href="http://vimeo.com/tomallen">Tom Allen</a> on <a href="https://vimeo.com">Vimeo</a>.</p>
    Salsa El Mariachi SS
    Roca Roja Breezy 29+ SS
    Flat Tire Bike Shop, Cave Creek, AZ
  22. #122
    My preferred method.
    Propane/bhutan gas:
    MSR Whisperlite og Dragonfly.
    White Gas, diesel, Jet A1, etc; Primus Omnifuel.
  23. #123
    Stoves gone wild
    Don't know if this has been posted yet, but I might try this, as I am a coffee addict. HEET storage elsewhere though.
    http://www.youtube.com/watch?v=-szOgg54f8k&sns=em
  24. #124
    gran jefe
    instant coffee? why doesn't he just punch a baby? just go with turkish coffee... cool setup.
    with the heet, if you spill it in the can it evaporates completely, BUT it leaves behind a very bitter residue. i'd definitely want to store it elsewhere too.
  25. #125
    Stoves gone wild
    A friend of mine carries it in a metal fuel bottle on the back of his seatpost. Nice out-of-the-way spot if you're not using a seat bag.
