Results 1 to 23 of 23
Thread: Singlespeed
    Harshing my mellow, man..
    Singlespeed
    Does anyone ride a singlespeed when bikepacking? My bike this year is in singlespeed mode, and I was trying to get an idea on how bad it's going to hurt.
    @adelorenzo
    Reputation: anthony.delorenzo's Avatar
    I do. Sometimes I try to gear down one or two teeth in the back when riding loaded, sometimes I don't.
    lord of my world
    Reputation: surlywhore's Avatar
    Dec 2005
    I did a short 80 mile loop on my SS last summer and it was fine, had to push a little more.
    Reputation: jmmUT's Avatar
    I do also. Like what was already said you might want to consider adding a couple teeth depending on the route. But since my bikepacking routes are usually less climbing and less tech than a typical day ride it usually works out to keep the same. If it's too easy that's annoying though to be spinning too much.
    If anything, it's a good reason to really work on dropping gear weight for your trips.
    Cheesiest
    Reputation: intheways's Avatar
    I have my bike setup SS also. What do y'all do for trips that include long sections of flats? Gear for the flats or the hills?
    "Paved roads...just another example of needless government spending"—paraphrased from rhino_adv
    Ahhh the pain....
    Reputation: Raybum's Avatar
    I basically ride a 33x19 unloaded, then run a 32x20 when I bikepack (very similar trails). If I'm doing a trail like the Arizona Trail where grades can reach 20%, I'll go to a 32x21 and considering a 22t for my next AZT300 ride.
    Yeah, you do some walking, but on those long rides, it's a welcome change and let's you use different muscles.
    Mar 2013
    If this guy can do it, so can you!
    GT Peace 9r
    I have just done 900 odd km in 8 days, slideshow posted in film thread here
    Is it going to hurt, make that a YES!
    Trail Rider
    I have a geared bike and SS, if its a short ride or I know its not going to be a difficult ride, I may choose to use the SS.
    I've not regretted it yet, atleast
    Reputation: stevland's Avatar
    I've done one overnight on my SS. Gear for the climbs
    Time to go farther
    It's not that different. If you ride a SS everyday and pack light then it's fine bikepacking. I rather enjoy it more than gears actually.
    On-One Lurcher SS
    Speedway Cycles Fatback Ti SS
    1984 Trek 560
    http://slipangles.blogspot.com/ - It's supposed to be fun
    SpoK Werks Handmade Goods
    Reputation: 1 Speed's Avatar
    Singlespeed
    Yup... I did the Tour Divide Race on a singlespeed. My opinion, it's basically the same as normal singlepseeding with more weight. Therefore, you need to consider the extra work or changing your gearing. Have fun!
    Did I catch a niner+?
    Wanted to revive this thread and hear from some others. I have my commuting/touring rig currently setup fixed gear 36x16 and it seems to be fine loaded for me but have an opportunity to get my hands on a Sturmey S3X.
    Thoughts on fixed gear sturmey and what are others riding fixed gear? I think my limit is going to be 100 miles on this setup.
    Specs:
    18in Inbred
    Enabler Fork
    Fat Sheeba w/ Endo
    LX Cranks w/ 36t
    Stans Flow w/ Paul WORD disc
    Velosolo 16t
    Schwalbe Big Apple 29x2.35 tubeless
    Titec J Bar
    BB7 front 160mm rotor w/ XTR lever
    Ibera RA5 rear disc rack
    M Tangle bag
    Mr Pink, Love to see photos of your rig
    Quote Originally Posted by demondan View Post
    Ask and you shall receive.
    As it stands now I want a IGH for the rear and maybe a dymo hub up front but we will see. I am kind of trying to go for the Jones Diamond Frame ATB with 135mm front rear and being able to swap front/rear if I am in a pinch.
    Quote Originally Posted by Mr Pink57 View Post
    FYI - The front wheel on a Jones has 135mm FRONT disc spacing. I think it differs from a standard 135mm rear by 5mm, so it's not a dollar for dollar swap between front and rear wheels. There are only a few front hubs with that spacing (Jones, Paul WHUB, Origin 8). In other words, I don't think you can just throw a 135mm Surly SS hub in the Jones fork like you can do with an Enabler fork.
    Enjoy the ride!
    I have an enabler up front with a Surly hub . I like this setup even better.
    Looking to ride the Idaho Hot Springs route this summer on my Nimble 9 singlespeed. Currently I run a 32x 17 which is okay up to about an 8% grade. Thinking about the White Industries Double Double white industries double double. That will give me a 34 x 16 and a 31 x 19 for climbing. Not to much of a weight penalty and I get to keep that great SS feel.
    I don't see how you can go dyno upfront and still be able to swap it to the rear if something goes sideways... Unless you get a 135mm dyno and do a bolt to the disc cog so you could fixed gear out.
    Quote Originally Posted by bmike View Post
    Currently as the bike stands it is fixed gear on the disc. I am going to not go dyno hub and just stick with lights the old fashion way of a battery.
    iphilrive
    Reputation: iphilrive's Avatar
    Jan 2013
    you could always run a dingle speed and change your gear ratio as needed!
    instagram: _skinnytwig
    hi paul.
    Apr 2014
    Wow, that looks awesome :O How's she ride? Do you use her for touring on the road too? ;p
    Quote Originally Posted by iphilrive View Post
    After looking at the Dingle I have decided to go with the Alfine 11. I just think with all of those long sustained climbs day I after day the SS with extra weight would wear me down. Easy to convert to the Alfine when I want it and take it off when ii don't.
  1. Replies: 41
    Last Post: 09-27-2012, 08:56 AM
  2. Is singlespeed for me?
    By reedfe in forum Singlespeed
    Last Post: 07-03-2012, 05:42 PM
  3. My First Singlespeed
    By IrieRider in forum Singlespeed
    Last Post: 11-30-2011, 01:07 PM
  4. What's a Singlespeed?
    By subliminalshiver in forum Singlespeed
    Last Post: 06-29-2011, 12:55 PM
  5. My new Singlespeed
    By fishcreek in forum Singlespeed
    Last Post: 03-29-2011, 11:57 PM
