• 02-09-2013
    alexvi
    Please suggest hardtail for touring
    I would like to get a new hardtail for touring. 90% is on paved roads, so I think locking fork is a must. Price about $800. What makers/models should I look at? New vs used?
    Another possibility is to fix the bike I have - Schwinn Frontier GSD. But this will require replacing pretty much everything - fork, breaks, deraulers, pedals, probably bottom bracket. Plus mechanical work, and I am in no way an experienced mechanic. I am willing to learn though. Good idea/bad idea?
    P.S. Road bike/touring bike is probably not an option. I like the offroad, even if it is only 10%. No jumps or anything crazy though, simple offroad.
  • 02-09-2013
    Jstews
    I would keep my eyes on the local craigslist and ebay. Once spring gets here, prices in the used market will go up a little, but choices will be more abundant.
    Usually budget friendly suggestions in one way or another involve the name Surly. I can attest the the awesomeness of the Karate Monkey and the Cross Check.
    I would forgo the susp. fork, and stick with the rigid, especially if you'll be spending more time on roads. The KM can fit large enough tires to dampen any rough stuff when you do find yourself on trail.
    That said, you might be able to get away with a more touring oriented or cyclocross bike.
  • 02-09-2013
    Crudcake
    The Salsa Vaya sounds perfect for this. They're way more expensive, but maybe you can pick up a used one.
    CC
  • 02-10-2013
    Aushiker
    I have done a bit of touring on Giant XTC 2 so guessing any reasonably priced hardtail would do the trick.
    My most recent play with the Giant XTC2 was on the Waterous Trail but have done longer tours with it.
    Andrew
  • 02-10-2013
    jddjirikian
    Salsa Fargo. Perfect for light singletrack and paved roads. Might be a little more than you want to pay though.
  • 02-10-2013
    Hand/of/Midas
    Surly and Salsa have some perfect options, even the ogre would be perfect, but like you said they all go a bit over the price range.
    I'd go on an Ebay spree and sell all my old stuff and try to save up. The difference between a bike designed to carry tons of stuff and retro fitting any basic mountain bike is significant.
  • 02-10-2013
    alexvi
    Thank you all for the suggestions. I looked at them all. However, they are a bit above my price range (I'm sure for a good reason). For now I will go with modifying my existing bike - it is also much more fun this way :)
  • 02-10-2013
    big_papa_nuts
    I'd think that most hardtails or ridgids in that price range will do you fine. Obviously there are some ideals you'd be shooting for; steel frame, braze-ons, 29er, and obviously better components are gonna make for less troubles. But if you can strap stuff to it you can tour on it.
    If you do go for a new bike I'd tell you to make sure you get a good frame over anything, everything else can be slowly upgraded. Maybe buy a Surly Troll and swap your parts over?
  • 02-10-2013
    alexvi
    That's what I thought, but there are so many... Hoped to narrow the range by getting some suggestions. Got quite a few, but not in the price range.
    I think so too.
    Wish I knew how to see a good frame...
    Looked at this one too. Again, a new one is out of the price range ($1400 is what I get from google). What I decided to do is the inverse - get the parts I want and slap it on the frame I have. I suspect this will be enough. I don't really know if my frame is good or bad. Nothing on it screams "bad" to me. So that's the plan for now.
    P.S. The parts I am getting are:
    - Manitou Minute Expert Suspension Fork 100mm Black QR w/Bosses
    - WELLGO MG-1 PEDALS
    - 2x Avid BB7 Disc Brake Caliper w/ G2 Rotor 160mm
    Good/bad/stupid?
  • 02-11-2013
    big_papa_nuts
    What I meant is that you could get a Troll frameset (less then 500 on google) and have it built with the parts off your current bike, while replacing what NEEDS to be replaced. Honestly it may be the best approach to just ride you current bike and upgrade as needed. I'd also tell you to consider the need for a suspension fork. The simpler you can make your bike the easier your life will be.
    BB7s though = :thumbsup:
  • 02-11-2013
    Gregon2wheels
    I guess I'm not sure why you would invest $800 in parts on a frame that was part of a bike that cost $450 new. IMO you'd be better off starting with a better frame.
    Again, just IMO, but I don't understand what you are trying to do with the parts you've picked. I'd be looking at something much more road that could do some off-road.
    Something like this: 2007 Specialized Tricross Sport Triple Cyclocross CX Cross Bike 54cm Olive Green | eBay might be a good starting point as an idea. A CX with a triple.
    Good/bad/stupid?
    If you really are going to be 90% road, then I would recommend against a suspension fork (no need on the road and many of us have ridden rigid off-road at one time or another) and in favor of clipless pedals (maybe a platform/SPD combo like the one below).
    Jury is still out on disc brakes for road. One anecdote: Road Bike Disc Brakes Are Coming, But Will They Work? - Bike Rumor
    You will save $$ going with rigid and rim brakes. You won't need to spend much more, if any, on clipless + platform pedals. That might free up some money for a frame.
  • 02-12-2013
    alexvi
    This is a very valid suggestion. I was thinking about that too. If I get the parts now and the frame later, wouldn't it be the same as getting the frame now and the parts later? My parts are pretty bad, so I suspect better parts will improve my ride more than better frame. May be wrong here.
    I think I will miss it if I don't have it. That's why I keep insisting on it, even though many suggest rigid. I guess if the fork breaks in the middle of nowhere, I will learn my lesson then :)
    Thanks :). I try to do my research.
  • 02-12-2013
    alexvi
    $450 in parts. If I get a new frame later for another $450, that's in the ballpark of the total $800 I mentioned in the opening comment.
    As I am not a very experience rider, I can't say that I know what I am doing. I do want front suspension though - I've been to places where I would be sad if I didn't have it. So I want a road bike with front suspension... or MTB for road... pretty contradictory, I know.
    Will it do well on a trail like this? Random picture, but I've been to similar. That's my 10% that I don't want to lose.
    http://curiousimagery.com/curious_ph...l_kauai_01.jpg
    Was looking at clipless. I probably will kill myself on a trail with them, so I will go with platforms now.
    I like disc for the coolness factor :) That's the only reason really.
    As I mentioned in a post before, I don't really understand what a better frame is, and what it gives me. I can see how better fork, pedals, and breaks make my ride better. Please point me to a reading/post/explanation. Thank you.
  • 02-12-2013
    cpfitness
    Re: Please suggest hardtail for touring
    Any place where you might actually need a suspension is probably somewhere you shouldn't be riding with panniers fully loaded
    Sent from my DROID RAZR using Tapatalk 2
  • 02-12-2013
    cpfitness
    Originally Posted by cpfitness View Post
    Any place where you might actually need a suspension is probably somewhere you shouldn't be riding with panniers fully loaded. 38c cx tires will do you well on dirt roads
  • 02-12-2013
    alexvi
    Definitely. For now I want to mix short tours (a night or two) with trail biking. So I won't actually have both harsh trail and panniers at the same time.
    The long-term plan is to go touring (late summer maybe). Then I want to have the freedom of going on a trail if I see one. Still trying to figure out what I would do with panniers then.
  • 02-12-2013
    big_papa_nuts
    Alex, are you in Hawaii? I'm actually gonna be out there, in Kauai, on the 20th.
    Anyways, from experience I can say that a rigid can go almost anyplace a hardtail can, you just have to pick your lines better. You will also want to pay attention to your PSIs more. And soft luggage will go a long way when riding loaded off road.
  • 02-12-2013
    alexvi
    No, I'm from New Jersey. Would love to tour Hawaii, but for now my experience includes only a single overnight trip to the local camping site. I would like to build some experience with short trips, then bike the east coast, as it is closer to my home.
    Yes, rigid has been suggested so many times that I am wondering if I'm being overly stubborn here. Maybe I will get a rigid fork, put it on my current bike, and make a few rides to see how it is. I have a suspicion I won't like it, but it is not backed by any experience. And I imagine it is a relatively cheap experiment to do.
  • 02-12-2013
    cpfitness
    It is much easier and cheaper to start with a ridgid and then decide you want a suspension fork later than to spend exorbitant money on a suspension fork only to find out that your riding really doesn't require it. Quite frankly, it's sounding more and more like you need 2 separate bikes altogether. I have a surly disctrucker, road disc brakes are great, if I put knobbies on it, I know it could easily handle dirt roads no problem, but if your really looking to do some touring and some serious trail riding the ridgid fork Surly Troll or karate monkey is probably the way to go. if you look around on ebay you may find one of those frames used for a couple hundred.
  • 02-12-2013
    Aushiker
    Totally 100% disagree with that sentiment ... There is heaps of fantastic touring to be had where suspension forks are very desirable indeed.
    Andrew
  • 02-12-2013
    cpfitness
    Andrew
    Our definitions of touring are probably quite different. Id love to see someone ride my trails with panniers. Frame bags sure.
  • 02-13-2013
    alexvi
    Yes, sounds like that to me too. But I can't take two bikes to a tour :). So I am looking for the right kind of hybrid.
    Thanks for the suggestions. I will definitely keep my eyes open for these and for CraigsList and Ebay in general.
    I think this is the touring I am searching for. And the right kind of bike to go with it.
  • 02-13-2013
    richwolf
    You can get a brand new titanium 29er frame and reba fork with lockout for under $1100. Great setup for bikepacking. It doesn't have rack mounts on it BUT if you want to go with a rack then get an OLD MAN mountain rack which attaches to the rear quick release and you use a couple of clips to attach the top part to the seat stays. Solid system. Or you can just go with frame bags, seat bags and a handlebar sling along with gas cans and feed bags.
    I never really understood hybrids. To me they seem to be the worst of both worlds. Not fast like a road bike and pretty horrible offroad when the going gets rough. They are probably fine as a fitness bike if you are not worried about speed or ever doing any true off roading.
    A 29er mountain bike will accept road tires, hybrid tires and mountain bike tires so it is the most versatile bike out there.
  • 02-13-2013
    alexvi
    It seems that's what I'll do. I'll use my existing frame for now, but may eventually replace it. I also was reading about Reba vs Manitou forks, and it seems Manitou will do fine for me.
    I actually have a rack (topeak I think) that fits to my current bike. So that's fine for now.
    I never really understood hybrids. ... They are probably fine as a fitness bike if you are not worried about speed or ever doing any true off roading.
    That's me :) I'm not into racing - I prefer to go slow and enjoy the scenery. I'm also probably going to kill myself on any true off roading, so I don't do that either. That's why I think I will be fine with a hybrid. Even though it is the worst of both worlds, it gives me both worlds to enjoy.
  • 02-13-2013
    cpfitness
    Stand up straight and turn your torso and around your lower body and see how many degrees of shoulder turn you can make. For me being a low handicap golfer, I can easily turn a full 90* and then some. now stand up straight and hinge at your hips until your torso has come down about 45* then try to see how many degrees of shoulder turn you can make. IT will be drastically reduced. On a road bike, you have very little visibility around and behind you because as your spine angle tilts, the ability to rotate around your torso decreases. IT's not big deal on a racing/road bike, you are focused on what is in front of you and going fast. Hybrids are designed to give you the upright positioning that will let you see around if your commuting and not force you to have strong abs to maintain the hunched over aerodynamic position. There are so many types of hybrids these days but many of them are WAY faster than a MTB and Way more versatile than a race bike. Put 32mm CX tires on a flatbar hybrid and you can take it down a bumpy country dirt road and easily rip away at 20mph. that wont be too fun on a road bike with 23's on it.
  • 02-13-2013
    richwolf
    Well if you can name me a hybrid that I would gladly sell my present bike for then you win!! ;) You can change position on just about any bike to get the fit you want. For example long low stem with flat bars vs. short high stem with riser bars. Tour divide riders add aero bars for long stretches of road. That is about as much of a dirt road long ride as you will find anywhere and folks aren't using hybrids for that.
  • 02-13-2013
    t0pcat
    Attachment 771630
    how bout something like this? This is my fargo which i got a deal on in i think july its a 2012 i put the fork and flat bar on which cost almost as much as the bike!
  • 02-14-2013
    cpfitness
    The giant rapid is a flat bar road bike with geometry similar to their defy road bike but not exactly the same. Its one of the few hybrids on the market that uses caliper brakes instead of cantis or vbrake. Throw some cx tires o. It and hoj would be pleasantly surprised.
  • 02-17-2013
    Aushiker
    I guess they are.
    I have ridden single track with my trailer and a friend with his panniers ... the Munda Biddi is a mix of track forms including single track, pea gravel descents/ascents and fire roads for example. Sorry but I don't have photos of the single track; I guess I was more focused on riding on those sections but others may have.
    The Waterous Trail is an off-shoot of the Munda Biddi ... sorry but not many photos of the single track ... this one gives a hint of the overgrowth at least
    Also check out the riding of the likes of the Bicycle Nomads through South America ...
    Andrew
  • 02-17-2013
    cpfitness
    Fair enough but if you could pull a trailer on singletrack you obviously didnt NEED a suspension fork, you chose to have one
  • 02-17-2013
    Aushiker
    Clearly your experience with panniers and trailers and riding pretty rough stuff is different to mine. I ride the same trails without the trailer as I would with it; more so now that I am pulling an Extrawheel Voyager and as far as I am concerned I much prefer the suspension fork. Could I ride it without? Of course I could and I have done single track on a Surly Long Haul Trucker. Is this my preferred ride choice for such tracks? No.
    So personally I will stick to use my bike with a suspension fork when it suits me.
    Cheers
    Andrew
  • 02-18-2013
    Skeeno
    For $100 more, you could have this...Sette Razzo 29er X7 20in Bike - DEMO at Price Point
  • 03-06-2013
    RandomGuyOnABike
    After doing a bit of research, I decided to go with a Giant Revel 1. Its fairly "inexpensive", $530 or so for the bike, and it seems like it'll do the job. I'll post a more thorough review with it once I get it equipped. The one issue I'm having now is getting a frame bag. It will need to be custom made.
  • 03-06-2013
    Gregon2wheels
    Does it have rack eyelets? I know a lot of the Specialized bikes do. I would thing that a rack and panniers would be a lot less expensive than a custom frame bag.
  • 03-07-2013
    RandomGuyOnABike
    Yep, it does. That was one of the things we looked at when I went to "eye" the bike at my LBS.
    my planned bag layout may be a bit excessive for short term trips, but if I can make it out for month long+ trips, i'll need the space. Going to check around at my local seamstress shops to see what they'll charge to make the bag if possible.
  • 03-07-2013
    TobyGadd
    Sounds like you ride harder trails, but I've completed the Colorado Trail Race with panniers and an old 1994 Cannondale hardtail. Worked pretty damn well. While I now prefer my full-suspension bike with a seat bag & frame bag, there's no reason why someone can't have a great bikepacking experience with panniers.
  • 03-08-2013
    kardar2
    i AM GETTING READY TO BUY A Surly Ogre for touring and then use it for a commutter to work. you can put Fenders and racks on it at the same time . it is a 29er
  • 06-19-2015
    Cacher
    i am really liking that Salsa Fargo idea.
