Results 1 to 20 of 20
    Please reccomend rear and front racks for a frame with no rack mounts.
    the frame i have is perfect for my next project, only it lacks rack mounts. going to a frame that has mounts that i can afford right now will be too heavy for my needs.
    thx
    Google old man mountain
    Their racks fit almost anything.
    Reputation: broz's Avatar
    Feb 2007
    revelate designs seat bag?
    yes great racks, but my frame has no canti mounts.
    unless i can use these instead????
    oldmanmountain: 3/4 inch OMM Band Clamp one pair
    Reputation: jmmUT's Avatar
    Quote Originally Posted by ascarlarkinyar View Post
    Yes and you can get the exact same thing-same quality and all from any hardware store for far less. Like a dollar or two.
    I guarantee also that as long as you tighten them completely, and re tighten after breaking in, they will work just as well as mounts. Even with heavy loads.
    Positively negative
    Salsa, Sunlite, and Electra make seatpost clamps with rack mounts, and Tubus makes a QR adapter for their racks. Axiom also makes a rack that will work without mounts.
    I'd also a consider seat/ bar bag. They work well and can't cost much more then a retrofit.
    Unhinged Aussie on a 29er
    Reputation: hunter006's Avatar
    Tour rack | Top | Freeload
    Freeload racks are specifically designed for this and work great.
    The band clamps also work pretty well. I've had one fail on me in the past after 2 years of wet, heavy usage. The rubber cracked and the racks moved around a lot. The issue could be avoided by inspecting the rubber prior to going on the trip. The other thing to do is tape the frame 1" above and below the clamp mount (this also applies to Freeload racks) to protect the frame and clearcoat.
    Reputation: Aushiker's Avatar
    Quote Originally Posted by hunter006 View Post
    Freeload racks are now part of the Thule Pack n' Pedal range of products. Haven't been able to locate where they being sold so if anyone knows ...
    Andrew
    I don't have a rear rack on my Giant XTC 2 but I have fitted a Tubus Swing on the front. I am yet to use it in anger so no experience to share. Still it may be something to consider.
    More photos of the install are available on Picasa.
    Andrew
    ColoradoCoolBreeze
    Reputation: SingleTrackLovr's Avatar
    So few details in your question.
    I don't see how anyone can offer a good answer for the proper racks without knowing what when where how.
    Are you bike packing a concrete bike path, dirt road, singletrack in the mtns? What kind of bike are you building?
    Will you be racing or camping out for multi weeks?
    04 Azonic Saber
    08 Yeti AS-x
    12 Rocky Mtn 29er Alt 970
    Quote Originally Posted by SingleTrackLovr View Post
    What sort of racing would require racks?
    I assume given that the post was made in Bikepacking and Expedition that the OP wanted the racks for bikepacking and/or expedition riding.
    That said more details would be of value.
    Andrew
    Moderator Moderator
    Reputation: mtbxplorer's Avatar
    Dec 2009
    Quote Originally Posted by Aushiker View Post
    Andrew
    Universal Cycles -- Product Search - 5 Products
    Quote Originally Posted by mtbxplorer View Post
    Thankyou.
    Andrew
    they will be going on a bike that will be a commuter, a bike camping mule and self supported endurance racing.
    the freeload rack looks like a great choice so far. being able to switch them to a different bike easily is a huge bonus. the only draw back is the front rack is not able to be used as a lowrider. i have gotten use to having my front weight lower and i like it for long heavy road tours. the mountain biking stuff is fine wear they have it. too low and your bag snags on rocks.
    ColoradoCoolBreeze
    Andrew
    The 500 mile Colorado Trail Race comes to mind. Multiday trail racing has become quite popular. Requiring better gear than the old panniers and wire racks.
    Colorado Trail Race
    04 Azonic Saber
    08 Yeti AS-x
    Colorado Trail Race
    Sounds interesting. I haven't come across this sort of racing here. We have multi-day races but generally they are supported (i.e., gear carried for you).
    Andrew
    Reputation: junior1210's Avatar
    Depending on what kind of pack/bags you're using the Carradice Bagman 2 could be useful to you. These are meant for the classic style saddle bags but it could work for others as well.
    Attached Thumbnails Attached Thumbnails Please reccomend rear and front racks for a frame with no rack mounts.-sunp0024.jpg
    The ridiculousness of cycling clothes increase exponentially in relation to the distance from your bicycle.
    May 2012
    If you want a cheaper option, Blackburn do one called the 'disk-compatible EX-1' which is decent. You'll need p-clips if you don't have the necessary bolt holes. It's also about half the weight of the old man mountain "Sherpa" rack.
    May 2012
    Quote Originally Posted by Harryonaspot View Post
    Wife rode dirt-roads/off-road from Guatemala to Mendoza (Argentina) with a set of OMM Sherpa disc-compatible rear racks (onto seat-stay clamps). No issues - as another has commented, re-tighten the clamps after a few hours use. Agree that a DIY alternative to the clamps would be easy.
