Results 1 to 6 of 6
    Ogre or Fargo Fork for my Karate Monkey
    I'd like to replace the fork on my '11 Karate Monkey with a new fork that has braze-ons. The stock fork is OK, but the only attachment points it has are for fenders. Both the Ogre and Fargo forks have a good complement of braze-ons for racks, cages, etc. They appear about equivalent as far as that goes. The Fargo fork has stainless dropouts, which sounds good. The Fargo fork is also somewhat lighter; 1.158 kg vs 1.4 kg. With its lighter weight, I imagine the Fargo fork has more flex to it. Ogre fork has canti studs. Same axle to crown dimension. 2mm difference in rake.
    Thanks for any pointers.
    Reputation: broz's Avatar
    Feb 2007
    I have a surplus fargo fork. I cut it down a bit. Let me know if you are interested and I can measure it for you.
    Positively negative
    Fargo fork is good stuff. Very compliant and well designed. The Ogre fork is ok but quite a bit more "dead" then the Salsa, or the KM, fork.
    I actually just picked up a '13 KM and am debating swaping the stock fork for a Fargo because I like them so much.
    Reputation: Jstews's Avatar
    Oct 2011
    The other option is to have a few bottle bosses added to your fork if there are any framebuilders in your area.
    big_papa_nuts - Yeah, that's exactly the sort of feedback I was hoping for, and confirms what I expected given the lighter weight of the Fargo fork. Enjoy your new KM.
    Jstews - I wish I had a local frame builder.
    Two Headed Boy
    Reputation: Trower's Avatar
    You could find a good welder and have him mod your current fork. I have braised stuff on my frames a few times with good results.
    Quote Originally Posted by Spinymouse View Post
    tSETFREEBYLOVEt
  1. Karate Monkey fork on Paragon?
    By JonathanGennick in forum 29er Bikes
    Last Post: 05-20-2012, 08:37 AM
  2. 120 mm Fork on a Karate Monkey??
    By neilether in forum Surly
    Last Post: 04-23-2011, 07:55 AM
  3. G2 fork on Karate Monkey?
    By lucero in forum 29er Bikes
    Last Post: 04-21-2011, 11:08 AM
  4. Anyone run a Niner carbon fork on a Karate Monkey?
    By appleSSeed in forum 29er Bikes
    Last Post: 03-16-2011, 09:58 AM
  5. Karate Monkey Sus Fork Recommendations
    By terrysol in forum 29er Bikes
    Last Post: 03-10-2011, 01:19 PM
