    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Moots snoots YBB for sale.
    <div style="text-align: center;">
    <div class="separator" style="clear: both; text-align: center;">
    <br />
    SPAM pass here.
    <br />
    <a href="https://picasaweb.google.com/lh/photo/l-QQjZRYPY-41CCllqk16y-KVKgt3fngH75sqrTbhXQ?feat=embedwebsite" style="clear: left; float: left; margin-bottom: 1em; margin-right: 1em;"><br /></a><a href="https://picasaweb.google.com/lh/photo/l-QQjZRYPY-41CCllqk16y-KVKgt3fngH75sqrTbhXQ?feat=embedwebsite" style="clear: left; float: left; margin-bottom: 1em; margin-right: 1em;"><br /></a><a href="https://picasaweb.google.com/lh/photo/l-QQjZRYPY-41CCllqk16y-KVKgt3fngH75sqrTbhXQ?feat=embedwebsite" style="clear: left; float: left; margin-bottom: 1em; margin-right: 1em;"><br /></a></div>
    This is my all-time favorite do-all bike. &nbsp;It was built by Brad Bingham @ Moots.
    <br />
    <a href="https://picasaweb.google.com/lh/photo/l-QQjZRYPY-41CCllqk16y-KVKgt3fngH75sqrTbhXQ?feat=embedwebsite"><img src="https://lh4.googleusercontent.com/-IyZelj0rDcE/UqD3D3RYGYI/AAAAAAAAmY4/DgLjo7Mvvdw/s1600/4A4B0529.jpg" /></a><br />
    <br />
    <br />
    I call it "do all" instead of "snow" or "fat" because I've used it equally in all configurations--29", 29+, 4" fat and 5" fat. &nbsp;I've used it on bikepacking overnighters every month (and every condition) of the year, as well as day-rides on snow, and sand, and trail.<br />
    <br />
    The chassis is your basic Moots YBB softtail, designed to accept tires up to 4.7" wide.<br />
    <br />
    The fork is a custom Action Tec suspension unit, with clearance for a 4.8" tire. <br />
    <br />
    <a href="https://picasaweb.google.com/lh/photo/pp8RVm5a6sRUe6itpkltjy-KVKgt3fngH75sqrTbhXQ?feat=embedwebsite"><img height="504" src="https://lh3.googleusercontent.com/-V7_WVaaI_QU/UqD3A9zTyuI/AAAAAAAAmYo/50xN4n38Rnw/s800/4A4B0526.jpg" width="800" /></a></div>
    <br />
    <br /></div>
    I am 5'10" with a 32" pants inseam. &nbsp;Pretty much your average sized male. &nbsp;If you are ~5'9" to ~6' this bike can easily fit you with basic stem/bar/post/saddle adjustments.<br />
    <br />
    Pertinent #'s are 24" ETT, 12" BB height, 17.15" chainstay length. &nbsp;Pretty close to most 18" frames across the board.<br />
    <br />
    Note the under-the-toptube cable routing, and full housing runs from end to end. &nbsp;I wanted this bike to be as maintenance free as possible, and this was the best way to achieve that.<br />
    <br /></div>
    <a href="https://picasaweb.google.com/lh/photo/nU6uBXuNDraLnDiVLWO1LS-KVKgt3fngH75sqrTbhXQ?feat=embedwebsite"><img src="https://lh4.googleusercontent.com/-y-ZUybYd9wE/UqD3CYUm6qI/AAAAAAAAmYw/OHMWxCE-018/s1600/4A4B0527.jpg" /></a></div>
    <br /></div>
    <br /></div>
    </div>
    SLX direct mount der, Middleburn cranks, Action Tec ti rings, Phil Wood BB.</div>
    <br /></div>
    <a href="https://picasaweb.google.com/lh/photo/gw7COu5UAl3ADHCW6v6PaS-KVKgt3fngH75sqrTbhXQ?feat=embedwebsite"><img height="800" src="https://lh4.googleusercontent.com/-Zpf8yypGSs8/UqD3GJf34hI/AAAAAAAAmZA/zStfhmiOe8Y/s800/4A4B0533.jpg" width="535" /></a></div>
    <br /></div>
    <br />
    Shimano 12-36 cassette, SRAM X9 mid-cage der.<br />
    <br /></div>
    <a href="https://picasaweb.google.com/lh/photo/To_qCwsueJNx4A5YcmF1xS-KVKgt3fngH75sqrTbhXQ?feat=embedwebsite"><img src="https://lh4.googleusercontent.com/-axSaFgnA3wI/UqD3InidW4I/AAAAAAAAmZI/-XL6pfgof8g/s1600/4A4B0534.jpg" /></a></div>
    <br />
    <br />
    Hayes hydros on both ends. &nbsp;Alligator rotors--7" front, 6" rear. &nbsp;I mixed Stroker Trail calipers with Nine master cylinders to get the best cold-weather performance. &nbsp;Bonus that the levers are carbon--they don't feel cold when it's cold.</div>
    <br /></div>
    <a href="https://picasaweb.google.com/lh/photo/PUrEABK8vpQ6ZWePhVzoDC-KVKgt3fngH75sqrTbhXQ?feat=embedwebsite"><img height="800" src="https://lh3.googleusercontent.com/-8gcireo_x2w/UqD3KjNA5HI/AAAAAAAAmZQ/FXuKu7hoZLU/s800/4A4B0535.jpg" width="535" /></a></div>
    <br /></div>
    <br />
    DT Swiss 440 rear hub. &nbsp;Absolutely bombproof, yet easy to service--even trailside with no tools.<br />
    <br /></div>
    <a href="https://picasaweb.google.com/lh/photo/3viCYotkSbyRMB3n-yeFFy-KVKgt3fngH75sqrTbhXQ?feat=embedwebsite"><img src="https://lh5.googleusercontent.com/-GCEAVybudHQ/UqD3MA3goWI/AAAAAAAAmZY/k9ArEI1G-RU/s1600/4A4B0537.jpg" /></a></div>
    <br /></div>
    <br />
    Flat bars are custom by Moots: 32" wide by 20* sweep. &nbsp;Not a misprint.<br />
    <br /></div>
    <a href="https://picasaweb.google.com/lh/photo/J9t9A0m_R3gIWxPAWMylVi-KVKgt3fngH75sqrTbhXQ?feat=embedwebsite"><img height="537" src="https://lh3.googleusercontent.com/-_eXGT-opqlQ/UqD3NHcu3-I/AAAAAAAAmZg/Qn_UgK9EzLs/s800/4A4B0538.jpg" width="800" /></a></div>
    <br />
    <br />
    I used trusted 9 speed components on this build because 10 speed never blew up my skirt, and 11 speed is nice but as-yet unproven over the long haul. &nbsp;I chose X0 twisters because they are light, simple, durable, and the grip pattern has good 'traction' regardless of conditions.</div>
    <br />
    Worth mentioning that the drivetrain (shifters, chainrings, cassette, chain) was replaced this July. &nbsp;Shiny new then, ridden less than 10 times since.<br />
    <br /></div>
    <a href="https://picasaweb.google.com/lh/photo/IW1_xvXHjnb9SHivPpHauy-KVKgt3fngH75sqrTbhXQ?feat=embedwebsite"><img src="https://lh6.googleusercontent.com/-a2-_55Y5cmY/UqD3OGGF_TI/AAAAAAAAmZo/iPWBGuSNQg0/s1600/4A4B0539.jpg" /></a></div>
    <br /></div>
    <br />
    The hydro unit of the fork is very simple to work on. &nbsp;I fine-tuned it with lighter synthetic oil so that it is &nbsp;unaffected by temperature changes. &nbsp;Feels just as sporty regardless of July or December.<br />
    <br /></div>
    <a href="https://picasaweb.google.com/lh/photo/eIIQ8HbNfnXGp5TSYlOU9S-KVKgt3fngH75sqrTbhXQ?feat=embedwebsite"><img height="800" src="https://lh4.googleusercontent.com/-N3GfCjCPGVQ/UqD3QX-eQFI/AAAAAAAAmZw/0mGd0R-N9eQ/s800/4A4B0542.jpg" width="535" /></a></div>
    <br /></div>
    <br />
    Front wheel is a Paul WHUB laced to a Surly Rolling Darryl rim using DT Swiss Revolution spokes and DT Prolock alloy nips. &nbsp;This wheel was laced fresh last week, ridden twice since then. &nbsp;Shod with Bud and a tube.<br />
    <br /></div>
    <a href="https://picasaweb.google.com/lh/photo/35HknV687nTkk9zQsOT_1C-KVKgt3fngH75sqrTbhXQ?feat=embedwebsite"><img height="537" src="https://lh3.googleusercontent.com/-2Ne8VJc14hk/UqD3anxUebI/AAAAAAAAmao/ePQfAx2H4wI/s800/4A4B0559.jpg" width="800" /></a></div>
    <br /></div>
    <br />
    Rear wheel is the aforementioned DT Swiss 440 hub laced to a Surly Clownshoe rim using DT Swiss SuperComp spokes and DT Prolock alloy nips. &nbsp;Shod with Nate and a tube. &nbsp;This wheel is approximately a month old--maybe 5 rides thus far.<br />
    <br /></div>
    <a href="https://picasaweb.google.com/lh/photo/BlgpLgM9Dy87djQFJPyvei-KVKgt3fngH75sqrTbhXQ?feat=embedwebsite"><img height="537" src="https://lh6.googleusercontent.com/-3h08oKs1Zhc/UqD3ZZBAGYI/AAAAAAAAmag/ZnUsIAISjwo/s800/4A4B0556.jpg" width="800" /></a></div>
    <br />
    <br />
    King 1 1/4" threaded headset. &nbsp;But look closer and you'll see the silver ring between the frame and headset? &nbsp;That's an aluminum sleeve adapting the current headset to a 44mm headtube. &nbsp;In other words, the frame is future-proofed so that you can run any (tapered or 1 1/8" steerer) available.</div>
    <br /></div>
    <a href="https://picasaweb.google.com/lh/photo/-v4Hu8cEyc-GS-LDcp4_eS-KVKgt3fngH75sqrTbhXQ?feat=embedwebsite"><img src="https://lh5.googleusercontent.com/-cy1IzpG_yxw/UqD3YFgYwpI/AAAAAAAAmaY/EqMgiURIV3A/s1600/4A4B0554.jpg" /></a></div>
    <br />
    <br />
    RockShox Reverb 100mm drop post, WTB Aviator saddle.</div>
    <br /></div>
    <a href="https://picasaweb.google.com/lh/photo/eqyS58jc0h8B6MmIG9p21S-KVKgt3fngH75sqrTbhXQ?feat=embedwebsite"><img height="800" src="https://lh4.googleusercontent.com/-OWYhsBEX3us/UqD3W1ksdQI/AAAAAAAAmaQ/BDN-imS0B7I/s800/4A4B0553.jpg" width="535" /></a></div>
    <br /></div>
    <br />
    Plenty of clearance for the 100mm rim with 4" tire pictured. &nbsp;YBB unit at top, just out of pic. &nbsp;Prominent exposed bolts are for a rack--and it is included.<br />
    <br /></div>
    <a href="https://picasaweb.google.com/lh/photo/3pJ7B5Rxfpr5AOGfjLNu0y-KVKgt3fngH75sqrTbhXQ?feat=embedwebsite"><img src="https://lh5.googleusercontent.com/-kOtwyC2e6Jk/UqD3U1mBHyI/AAAAAAAAmaI/QlbW79wUpnw/s1600/4A4B0550.jpg" /></a></div>
    <br /></div>
    <br />
    No need for drivetrain tweakage--frame fits the 100mm rim with 4" tire and room to spare. &nbsp;2 x 9 drivetrain clears fine. &nbsp;10 speed would also clear fine, 11 speed would have yet more clearance than either 9 or 10.<br />
    <br /></div>
    <a href="https://picasaweb.google.com/lh/photo/Z-KZWJJ_jPnHBJ_7kLMr7i-KVKgt3fngH75sqrTbhXQ?feat=embedwebsite"><img height="800" src="https://lh4.googleusercontent.com/-HxZCYWaDBFk/UqD3TrrdgiI/AAAAAAAAmaA/V-4U1S0D60M/s800/4A4B0548.jpg" width="535" /></a></div>
    <br /></div>
    <br />
    Hard to aim the camera 'just so' to show the fork clearance. &nbsp;That's a 4.8" tire on an 80mm rim, and there is ~9mm of clearance on each side. &nbsp;Plenty. &nbsp;Haven't tried it with a 100mm rim and 4.8" tire, but I'm 99.9% sure it'd fit *and* have adequate clearance.<br />
    <br /></div>
    <a href="https://picasaweb.google.com/lh/photo/_3x-zolPHvMNXdXHq7ygBy-KVKgt3fngH75sqrTbhXQ?feat=embedwebsite"><img height="537" src="https://lh4.googleusercontent.com/-VvvNX0L0pIc/UqD3RjUB9-I/AAAAAAAAmZ4/14RiYcbqaJE/s800/4A4B0545.jpg" width="800" /></a></div>
    <br /></div>
    <br />
    Why am I selling it? &nbsp;I'd like to be able to run the fattest of the fat tires--namely a 4.8" Surly Lou on a 100mm rim. &nbsp;And this frame was built before that combo existed, so it won't fit.<br />
    <br />
    Otherwise I think the sporty geometry of this bike, coupled with it's simple, durable, nearly maintenance free suspension, is way ahead of it's time. &nbsp;I'll be sorry to see it go, but happy to make room for V2.<br />
    <br />
    Please scroll back up through the pics and note that every piece of hardware on the bike is either alu (chainring bolts) or titanium: all 3 bottle cages, rack mounts, brake mounts, rotor bolts, stem, bars.<br />
    <br />
    The pics above all show the Snoots in her full-fat winter trim. <br />
    <br />
    <b><u>Not shown but also included are:</u></b><br />
    <br />
    -full-size Revelate frame bag,<br />
    -rear rack,<br />
    -Spare boot and extra springs for fine-tuning the fork,<br />
    -Replacement YBB unit, for when that time comes,<br />
    Syntace P6 carbon seatpost, for trips where the dropper isn't apropos,<br />
    -Hopey steering damper. &nbsp;Doesn't work with the Action Tec fork, but will work with any other.<br />
    <br />
    <b><u>Also included is a second "summer" wheelset, with tires.</u></b> &nbsp;What that means is up to you. &nbsp;Want 29" rims with tubeless tires? &nbsp;Fine. &nbsp;Want 50 or 65mm rims with 3.8" tires? &nbsp;Sure, fine.<br />
    <br />
    My current summer setup is a 29+ front wheel (Rabbit Hole rim, Knard tire, tubeless) and a 26" x 65mm Marge Lite rim with 4" Fatback tire. &nbsp;After extensive fiddling with all available options I determined that this was the best, lightest, most efficient and floaty combo for where and how I ride this bike in summer. <br />
    <br />
    But if you've got different preferences, say so and I'll accommodate.<br />
    <br />
    Total cost is $8660. <br />
    <br />
    That price includes shipping within the lower 48. &nbsp;The bike is in Grand Junction, Colorado, and is available for pickup, *or* I may opt to deliver it as far as Salt Lake, St. George, Durango, Denver, Flagstaff, or anywhere in between.<br />
    <br />
    <a href="mailto:info@lacemine29.com">info@lacemine29. com</a><br />
    <br />
    Price is firm, only interested in trading if you've got a mint Shelby Cobra burning a hole in your garage.<br />
    <br />
    PLEASE read all of the details above before asking questions. &nbsp;If something wasn't covered above, also check <a href="http://forums.mtbr.com/fat-bikes/endings-beginnings-586973-post6517361.html">HERE</a>. &nbsp;<br />
    Thanks for looking!</-that></div>
    Hi.
    Reputation: jtmartino's Avatar
    1. Awesome description.
    2. Awesome pictures.
    3. This is how a for-sale ad should go. Good luck!
    Dec 2005
    Way out of my price range, and way too small for me anyway. However, I can't wait to see the next bike you come up with. By the way, the the expedition fatbike (with all the fuel tanks) get sold yet?
    Reputation: vikb's Avatar
    Quote Originally Posted by willapajames View Post
    Jill Outside: Impulse
    Safe riding,
    Vik
    www.vikapproved.com
  1. Moots Snoots YBB for sale.
    By mikesee in forum 29er Bikes
    Last Post: 12-06-2013, 11:21 AM
  2. Moots snoots YBB for sale.
    By mikesee in forum Fat bikes
    Last Post: 12-06-2013, 10:50 AM
  3. Moots Snoots expedition bike for sale.
    By mikesee in forum Bikepacking and Bike Expedition
    Last Post: 08-29-2013, 05:54 PM
  4. 2011 Moots Mootox RSL complete for sale.
    By LeeR in forum 29er Bikes
    Last Post: 07-25-2012, 06:51 AM
