• 11-22-2012
    SingleTrackLovr
    Bike Fit Specific to Bikepacking off road.
    I am starting to make small adjustment on my new29er. Something doesn't quite feel right on this one compared to my other two 26" mtn bikes.
    After about 10 miles the palms of my hands are going numb and the muscles in my lower back(each side of my lower spine) are stiff.
    If I lay on my back for 5 minutes they relax and I am good for the remainder of the trip. I don't experience this with my other bikes. All three bikes are FS.
    I currently have the seat adjusted so my knee is only slightly bent at the bottom of the stroke.
    My knees are 3-4 inches forward of the crank.
    Bar height is equal to the saddle height.
    My bike came with a 90mm stem and I felt a little too low and stretched out with a lot of weight on my hands so I'm going to try a 40mm stem.
    If the numbness persists I plan to try new handlebars with some rise and maybe a stem that has a bit more rise. To get a more upright position.
    Unfortunately Rocky Mtn cut my fork and there is no additional space to raise the bars.
    Any suggestions on the proper bike fit specific to bikepacking off road?
    thanks
  • 11-22-2012
    BikerDude001
    If you are having to go to a 40mm stem have you considered that your bike might be too large for you? A riser bar MIGHT help if you are lucky since a more upright postition might alleviate the strain on your lower back but if your bike is too large you might never get it right. You may want to try Ergon grips to spread the pressure on your palms.
  • 11-22-2012
    SingleTrackLovr
    Thanks BikerDude,
    I went with the 40mm just because I had one laying around. It's just to see if a shorter reach helps. I am using Ergon grips. I have them on all my bikes and love them.
    The frame could be too large I have a 33" inseam and the standover on this frame is 31.
    I have always preferred a larger frame or actually longer do to the cramped feeling of smaller frames or that sensation of man, I sure could go over these bars easy. haha
    If a shorter reach doesn't help, my next try will be a more upright position with raised bars and possibly stem as you have suggested.
    Thanks again.
  • 11-22-2012
    OneBadWagon
    Measure the saddle/grip/bottom bracket relationship to each other and the ground and compare with this frame.
  • 11-22-2012
    SingleTrackLovr
    Hi OneBadWagon,
    I'm not sure how that will help me.
    Neither of my 26ers are adjusted the same. They serve two different purposes.
    One cruiser one DH. Bike #3 the 29er is for long distance bikepacking from paved bike paths to gravel roads maybe some singletrack but nothing technical.
    That was why my title was specific to bikepacking esp with a heavy load of gear.
    I can't believe there is only one body to bike frame setup for all styles of riding.
    Bike 1- FS Azonic setup for mostly gravel road fishing trips.
    Sitting position is very up right almost like a cruiser bike.
    Bike 2- FS 180mm travel Yeti AS-X setup for downhill ski resort riding.
    Sitting position low and body position is weight to the rear since you don't do much peddling and want that weight to help with braking on a DH run.
    Seat is pushed back knee is probably 2" behind the crank.
    Darn-it no DH picts of this bike. I never take a camera to the ski resorts, sorry.
    Imagine this with the seat all the way down.
    EDIT: I may have answer my own question after writing this post.
    On both of my other bikes I am sitting more like you would on a motorcycle and now I have a bike setup in in more of a road bikers riding position.
    Dropping the seat an inch and raising the bars an inch might be the ticket.
    This old and decrepit body just can't stand being bent over so much.
  • 11-22-2012
    big_papa_nuts
    Remember the shorter the stem the lower your bars get, and the higher the bars get the shorter the cockpit gets. I'd tell you to try some bars with more rise and the original stem. My bikepacking bike is set up with a higher bar to seat height then my other MTB. The comfort is much appreciated after a few days and hundred miles. Also remember the higher your bars get the more weight you are carrying on your butt so make sure you have a saddle you like :) . Good luck.
  • 11-22-2012
    OneBadWagon
    Originally Posted by SingleTrackLovr View Post
    Hi OneBadWagon,
    I think you found what might be causing the issue. You're looking for a "one of these things is not like the other" number. In pedaling position, too much reach, too much drop, too little reach. If I find myself feeling funky on a bike, I just measure what I know works and try to see what jumps out as different.
  • 11-23-2012
    SingleTrackLovr
    Biker dude, OneBadWagon, big papa nuts,
    thank you guys for taking the time to help me with this issue.
    Rep power was added thanks again.
    I have ordered a new handlebar with some rise and will report back.
  • 11-23-2012
    fotooutdoors
    If you can get the numbers from the manufacturers, try to compare the reach on your various bikes (or you can do some rough measurements yourself). I find that my back doesn't like riding my road bike after a period without much road riding because its longer (probably slightly oversized) reach forces me into a more horizontal position. I think you are on to the right things by playing with different handlebars and a shorter stem. Good luck!
  • 11-23-2012
    CycleAddict
    Based on the photo of your bike and what you've said about it, I think it's too big for you. Your saddle height appears rather low for where it usually would be on a FS trail bike and running a 40mm stem to achieve comfortable reach is a sign of this as well. Not saying you couldn't ride the bike and be comfortable with some adjustments, but going one size smaller will solve your reach issue and allow you to run a proper length stem for your intended use of the bike. Only issue with one size smaller will be that the headtube will be shorter, but a higher rise stem and/or spacer stack underneath will make that a non-issue. Riser bars are always an option too obviously.
  • 11-24-2012
    Junktech
    Do yourself a favor and get fitted to your bike, I've done it on both my road and mountain bikes and it makes a big difference, especially if your doing long distance riding.
  • 11-24-2012
    SingleTrackLovr
    Thank you. I have come to that conclusion as well. This new bike has me bent over too much compared to my other two 26". For me the bike came with the bars too low.
    I've ordered a new set of handlebars and I'm about to test a 40mm stem just to see if that gets me in a more upright position. A 40mm maybe too much but it was something I had laying around so it's worth a try.
    Thanks for the suggestions. Is there really only one proper length stem? I haven't tested the 40mm yet it was just something I had laying around. I really like the size of this frame for many reasons and I believe I'll only need to get a little weight off my hands and my problem will be solved.
    Thanks for posting,
    When I go into my local bike shops(street and mtn) and start talking bikepacking I get deer in the headlights looks. They don't have a clue what I'm talking about.
    The street guys start talking about roadbike touring and the mtn bike guys want to sell me a DH bike because the ski resorts are so cool and why in the world would I want to peddle a bike with bags that weighs 60#
    Would you really want to spend $$$ getting advice from these guys?
    I firmly believe there is no one fit for every type of off road riding and since bikepacking is so new ( not road touring, riding on your nuts, that's been around forever) we really don't have any experts out there yet. So my plan is to let pain be my guide and buy parts accordingly. Thank goodness stems, handlebars, and seatposts are cheap.
  • 11-24-2012
    Junktech
    I guess I'm lucky, I have a Specialized BG Fit specialist who knows how to fit people right, good luck!
  • 11-24-2012
    SingleTrackLovr
    Cool nice to know some can pay for a proper fit. I don't think I can around here.
    But I do know I'll get the latest and best here from the guys that are doing it.
    How much weight are you hauling and how far have you hauled it?
  • 11-24-2012
    dream4est
    IMO on a 29er bar rotation, grip rotation, saddle tilt and fore/aft saddle position are more crucial than on a 26er. As I look at the many pix of your bikes here and on bikepacking.net I think you should do some adjustments in all four areas and see if small changes fix your problem.
    Even after over 4500 miles of singletrack bikepacking I sometimes overlook these crucial adjustments when dialing in the cockpit.
    Also, I would say that maybe no backpack could be a solution.
  • 11-24-2012
    SingleTrackLovr
    Hi dream4est, Thanks for the suggestions. If you've seen some of my TR's on BP.net then you know the types of trails I'm building this bike for. I have always worn a backpack mostly for the protection it provides when going over the bars on the Front Range singletrack and ski resorts. That 1.5L water bag has saved my bacon more times than I can count.
    This bike will see none of that. This bike is for rails to trails (<3% grade) bike path concrete to packed gravel with panniers loaded to ~25# max. A pack should not be required. I will give no pack a try.
    One think I've noticed in my daily riding is you don't really move around much on flat bike paths, heck I use all of 3 gears, and that stagnant riding position might also be a reason for my pain and why everything needs to be adjusted perfect.
    As you well know when one rides singletrack or a DH run you are all over the place. In the seat, standing, behind the seat, weight in the left peddle then the right, rinse and repeat. No muscle group gets a chance to go stiff.
    I hope to get my new riser bars middle of this coming week it should take less than 10 miles to know if it helped.
    thanks again rep point added.
  • 11-25-2012
    Entrenador
    "After about 10 miles the palms of my hands are going numb and the muscles in my lower back(each side of my lower spine) are stiff."
    The numb hands and tight back are likely both caused by fit issues, but perhaps the solution rests in multiple adjustments. My gut says that your primary issue is that you're having to squeeze the bars and tighten you're lower back while riding (especially uphill) because the saddle isn't keeping you properly perched above the cranks - you're having to use your grip, arms and back muscles to stay far enough forward.
    Tight back: This could also be in part due to lower-than-ideal handlebars, but it could be saddle tilt too. The nose is tipped up pretty far, and in some cases this will lead a rider to tighten back muscles unconsciously when climbing up hills. Specifically, a saddle that does not provide enough fore-aft stability (or "perch") will necessitate that the rider tighten lower back muscles in order to stay above the pedals, i.e. the rider will be forced to use back muscles to keep from sliding off the back when applying force the pedals. The right saddle, when properly adjusted, will keep the rider from sliding back.
    Also worth considering: These big-travel (120mm, yes?) 29ers are designed for rough trails and a dynamic riding style. If you're seated the majority of the time, you could be sitting deeper in the rear suspension than in the front, and this will mean that your seat tube angle (and thus the saddle tilt angle) will be exaggerated towards the rear. In your case, you might be riding a bit "too far off the the back" so to speak. Trying the higher bars will probably help, but I'd recommend raising the saddle a bit at the post, and then dropping the nose / raising the rear of the saddle a hair too - and do so incrementally: no more than 1/4" adjustment at a time between trials. You could also try scooting the saddle forward some too.
    As for the saddle itself: I see you're using a Brooks, which are notorious for being uncomfortable out of the box (and for perhaps 1000miles after). And, I'd venture to guess that you've got it tilted up because that naturally slides your weight towards the wider & more tolerable wider spot of the saddle. FTR, I learned after lots of trial and error that the B17 is too narrow for me. From what I've seen, they work best for slender folks with bars that are lower than their saddles. Because I ride bikes with level bars/saddles, I prefer WTB saddles, and specifically I prefer the wider Lazer model to their narrower Rocket model. I suspect you might find a much more comfortable position - in fact, a much greater variety of workable positions - by using something other than a new or near new Brooks. Try putting the stock saddle back on and see if you can find a comfortable position that leaves the saddle ~flat in profile and fairly far forward, then see if you can ride it without wrecking your back and hands. If you're successful, then try putting the Brooks back on and see if you can recreate that position. If not, dump the B17.
    Good luck.
  • 11-26-2012
    SingleTrackLovr
    Wow Entrenador that is some great advice.
    Thanks so much for taking the time to offer suggestions and provide the why for that adjustment. That really helps me understand the reason behind the tweak.
    On the saddle I have dropped the nose a little.
    I really like keeping the boys on one side or the other and if I go too level it can be a problem (ouch) a little upward tilt has helped me keep things where they belong. I didn't think about what you pointed out of pushing me back on the back side of the saddle.
    The new bars have not come in yet but I did some testing over the weekend.
    The 40mm stem did not help at all.
    Although it shortened the cockpit it dropped the bars as big papa nuts pointed out.
    I dropped by a local bike store and found a cheap stem in a discount bin for $12 with a bit of rise and I thought heck for 12 bucks it's worth a try. I did a 12 mile ride up Waterton Canyon (gravel road 6.3 miles steady 3% grade) I could tell I was sitting a bit more upright and it felt much better.
    I think I'm on the right track.
    As you can see in the picture below the bars are almost equal to the saddle.
    It is feeling better. Back muscles still got a little stiff but my hands did not go numb.
    I did make a couple other adjustment worth mentioning but not specific to my hand and back issues. They were more about making the overall ride more comfortable.
    Remember this bike is for rails to trails bikepacking with a load. No DH no technicals.
    Paved bike paths to packed gravel trails to gravel roads nothing more...
    The first thing I tried was lowering the front tire pressure from 80 to 45psi this really helped the SB8 in gravel and reduced vibration in the handlebars we all know how squirrelly SB8 are on the front. I might even try lower pressure in the future. I felt no increase in rolling resistance.
    The second adjustment was to drop the front fork pressure from 100 to 75psi.
    This gave me a preload sag with gear and backpack on of 1/2"
    While riding that 12 miles of gravel I could not believe how smooth everything felt.
    I'm looking forward to messing with the rear shock. Since I'm using panniers that support the weight at the axle and does not effect the rear shock I think I can soften that up a bit to and if things get bouncy I do have the propedal on the rear shock.
  • 11-29-2012
    IoC
    Hey man,
    Along the lines of what Entrenador said, have you tried leveling that saddle? I used a tilt a lot like yours on road bikes, but had issues with it when I changed to mountain biking.
    Having it too "nose up" seems to cause a lack of support to my tailbone, leading me to use overuse my lower back and obliques to stabilize my pelvis, taking away core strength that should be keeping me upright. That in turn leads to me putting too much weight on my hands.
    For me, it was a chain reaction of suck. Leveling the saddle supported a better pelvic angle. Some manufacturers, like WTB, are even making saddles with upturned 'whale tails' to help with this.
  • 11-29-2012
    Entrenador
    ...I'm looking forward to messing with the rear shock.
    Looking at your suspension sag o-rings in the pic, it appears that you might indeed be riding deeper into your rear suspension vs the front. Basically, your rear travel has been fairly active while the front hasn't budged much. On my F29 fork (set to 90mm), I ran ~80psi preload, and I weigh ~190lbs with gear on; I have no packs or load upfront other than myself weighting the bars. As well, I ride on the pedals a lot (vs on the saddle), both while descending terrain and while climbing hills (SS bike). 75psi doesn't sound like a lot of pressure, but depending on your weight, 75psi could be plenty. According to your fork o-ring, it's not too little psi.
    Long story short, the front preload looks adequate for your purposes. Might try bumping the pressure up by 20psi for shitzngiggles, and see how it rides then.
    Good luck.
  • 11-30-2012
    SingleTrackLovr
    Good luck.
    Wow good eye, thank you. I will try an additional 20# in the RP3.
    Part of that rear shock travel is I run without propedal a lot.
    For some reason without propedal the shock preloads and rides lower than with it on.
    I will use propetal for a long climb but prefer to not use it to increase ride comfort.
    I can usually control any bobbing by not spinning so fast.
    thanks again for your continued help I am learning with every post and that's a great feeling.
  • 11-30-2012
    Shmoo
    ... My gut says that your primary issue is that you're having to squeeze the bars and tighten you're lower back while riding (especially uphill) because the saddle isn't keeping you properly perched above the cranks - you're having to use your grip, arms and back muscles to stay far enough forward.
    Great post, I have lower back pain at times, I bet this is it. My bike came with a 15mm setback post, I just ordered a zero setback a few days ago.
    SingleTrackLovr, it looks like you have room to move your seat a bit forward, maybe give that a shot? That with your new stem might help your back.
    I, too needed a wider saddle, had a handful of different ones, but in the WTB group, I much prefer my new Pure vs my old Silverado.
  • 12-02-2012
    SingleTrackLovr
    So continuing my tweak and experiments on seat position I adjusted the seat to level and noticed right away it increased the pressure in my hands and it felt like I was being pushed forward.
    I did feel more over all body support . I believe it reduced the pressure on my lower back.
    So I think I need to raise the nose just a little to give me a more neutral feel.
    Thanks for all the tips guys they have really helped.
  • 12-02-2012
    Entrenador
    I had the same issue with the a Brooks saddle (not with any other brands though), and the one I still use on my commuter does have a very slight nose-up tilt to it now because of it. Keep in mind that if you end up bumping uo the rear suspension preload/psi, it will slightly effect your cockpit, saddle tilt included. If you're planning trying different pressures, be ready to make further incremental adjustments to your cockpit. Is it convenient / worth posting a pic of you in riding position on the bike from the side?
  • 12-02-2012
    t0pcat
    I'm not an expert but when faced with the problem your having i started with what i understand are the basics, first i adjusted my seat so my knee was over the center of the pedal in the 3 oclock position then seat height till it felt uncomfortably high and back down a touch then i took some measurements from all my bikes. First crank to top of seat then nose of seat to the crack in the stem above the bar then crank to crack in stem above the bar and discovered that my other bikes were within about 1/4" in those measurements so i set up thenew 1 to mimic those and was happy. Am still tweaking here and there but this seems to work for me!
  • 12-02-2012
    mtroy
    thanks
    I agree with a lot of the points in these replies. The bike looks too big for you, but it is what you have soooo...drop the nose of the saddle so you are not fighting sliding off the back...I think you mentioned you did this. As you bring the hbar back and up towards you, you will also increase the pressure on your sit bones and strain your back more with pedal efforts. Too upright and you cannot bring the proper muscle groups into play like you can with a correct position. So if flexibility is an issue for you, how about working on your fitness and flexibility instead of building a less efficient bike around your physical limits at this time? I am a back surgery patient so I know there can be wear and tear limitations on our old bods, but seldom is there a case where we cannot improve our flexibility.
    Just a thought.
    I do not think there is a 'bikepacking bike fit'. I do not change my setup much at all across SS, geared HTs, FS and whatever. Seat height and relation to hbar is the same. That fit is right for me and there is nothing about bikepacking that demands anything different. Now if I was on a DH bike, then OK....but that is not the case.
    As well, having the saddle too far forward will typically increase, not decrease weight on the hbars. Sounds counter intuitive, but placing your weight properly on the saddle fore-aft and in a decent relation to the crank is primary.
    Also, learn to set up your bikes suspension properly. Just saying I will add 25# and see what happens is like pin the tail on the donkey. Learn to do it right...set sag with the shocks fully open and go from there. That bike with Propedal on should be quite comfy on a rail trail surface.
    That goes for tire pressure too. 80 pounds! I am not even sure the tires are rated for that and you are NOT helping performance in any meaningful way by being at that PSI. Even 45psi is pretty high but in the ballpark.
  • 12-03-2012
    SingleTrackLovr
    Thanks again for your continued support and tips.
    I'm having a blast taking my shock pump and tools along for my daily rides. Sessioning sections of my local trail with different setting.
    I currently have the fork/shock sag set at 1/2" to increase ride comfort, no jumping no dropoffs other than the occasional curb.
    What I've noticed with this softer setting and equal static sag is the fork/shock do not compress equal amounts when sucking up a bump. If I want to see the o-ring indicator move the same amount the shock required more air so the static sag is no longer equal.
    Thank you for the tips t0pcat. I couldn't agree more. I did all the basic setup adjustment before my first ride. This 29er is just a little different than my two 26ers.
    I'm setting this bike up for more long distance riding, rails to trails nothing technical, and finding the static riding position for long period of time is giving me some pain in my palms and lower back.
    Some of this I'm sure is core body strength, palms and back are not use to riding in one position for so long without changing positions. Once I get the bike adjusted for minimum pain the rest will be fixed with hours in the seat. I'm close and having a ball seeing how the bike and my body responds to different settings. thanks again I really have learned a lot from this discussion.
    Just a thought.
    Great tips mtroy. I will try and get a picture of me in the riding position.
    I'm starting to agree with you on riding position for bikepacking vs say XC riding.
    With all my tweaks so far I am getting closer and closer to the riding position I have on my XC and DH 26" bikes. There is still plenty of weight on the bars so I don't think I'm setting up too high like a street cruiser bikes riding position.
    This frame does not feel too large. For me the longer wheel base is way more comfortable on the non techy stuff.
    Part of the reason the seat post isn't up like a XC racer is I'm running 175mm cranks and only have a 33" inseam. I can get two fingers between my top tube and crotch. The post has 0 setback but the seat is centered on the seat mount bars with no need to adjust the seat forward. My knees are 3-4" in front of the crank.
    The bike came with what I considered narrow bars.
    I prefer wider bars so I swapped to 720mm requiring a shorter stem going from 110 to 60. Still the handlebars felt to low. So I raised the bars about 1" with a new stem.
    This seemed to fix my hand pain and my riding position is more like my other two bikes. So I'm down to messing with the seat tilt for most comfort and shock/fork pressure to smooth out the bumps.
    Thanks again for the tips and discussion.
  • 12-03-2012
    SingleTrackLovr
    Looking thru my photos this is as close as I can come to me on this bike for now.
    Man does that curved mirror make me look fat. haha
  • 12-25-2012
    rifraf
    Hiya SingleTrackLovr, I like your choice of saddle but not the angle you have it - but thats just a personal riding preference. I was thinking maybe you could get a bigger (more rise) riser bar than you think you want and aim the rise towards you a bit to leave you less stretched out and shorten the cockpit. Not sure how it would go as it was just a thought. Does that make sense?
  • 12-25-2012
    SingleTrackLovr
    Hi rifraf,
    Thanks for joining in the discussion. Good advice.
    I did raise the bars, shorten the stem, level the seat and the bike feels better.
    With a level seat my boys have a little trouble deciding which side of the seat they want to be on. I'm hoping to get that worked out.
  • 12-27-2012
    Unchewable
    Maybe a jones h loop bar as it provides a variety of hand positions it is what i am looking at getting since i purchased my friends raced out epic marathon. Jeff Jones Bicycles - H-Bars
  • 03-21-2013
    Unchewable
    I ended up buying the jones loop bar got it today will post in the rig topic
  • 03-22-2013
    rifraf
    Hi Unchewable,
    let us know your impressions. I bought a large Surly Ogre frame to build up and am strongly considering the Jones loop bar to shorten the cockpit of my yet to be built ride.
    I'm sort of on the cusp of either M or L in frames. I like the amount of seat post showing but I'm aware that I'm going to feel stretched out on my choice of Large.
    I'm hoping a 50mm thomson x4 stem and Jones bar will help.
  • 03-22-2013
    SingleTrackLovr
    I to would like to hear how this H bar works out for you. Some picts would be awesome.
    Having several hand position should really help.
  • 03-22-2013
    Unchewable
    Will do tonight and compare to my carbon fsa. I think you are on the right track with the Thomson stem I am pretty sure I will need to get a shorter stem myself. My bike is a medium and very aggressive for me as I bought it from my buddy who was going for light and fast gran fondo style.
  • 03-22-2013
    vaultbrad
    I bet the bike isn't too big. I love my jones style bars. I can ride all day without issue. I would say that looking for a used titec version could be a good test for you. When I try a new setup I make sure to have some Allen keys around to make on the fly adjustments as necessary until it feels right.
    Also don't worry about whether your bike looks right to all. All that matters is that it feels right to you. If you are going for long days in the saddle, feel is most important.
  • 03-22-2013
    SingleTrackLovr
    Speaking of comparing bars.
    Yesterday I installed a cheap Al bar that has a little more sweep.
    Just to see how that feels. So far I like it.
    The H-bar looks like it has a bit more sweep.
    I was even thinking about a set of roadbike Aero bars but I think the H-Bars might be a better choice.
  • 03-22-2013
    SingleTrackLovr
    Thanks Vaultbrad, I'll be on the look out for a used titec version.
  • 03-22-2013
    JP...
    How does the effective top tube of your 29er compare with the ETT of your other mtb's? Is there a major difference?
  • 03-22-2013
    Unchewable
    Was chasing daylight and loosing the race but here is a quick comparison shot. Attachment 783644 and here Is the specs on my fsa bar for scale Attachment 783645. I will post finished shots of the hardware with the wtb grips they are similar to the gp1's.
  • 03-22-2013
    rifraf
    4 Attachment(s)
    That is the track I've gone down. I managed to pick up a Titec J-bar, off ebay, to see me through until I've enough spare coin for the Jeff Jones version. I like the look of the J-bar but it doesn't look compatible with my Ortlieb handlebar bag so I definitely need the full loop. Still for $22-50Au. delivered I cant complain.
    I'm not too keen on buying from Jeffs site though. No paypal nor secure link it appears:eekster:
    Attachment 783649
    Attachment 783682
    Attachment 783683
    For anyone whose budget doesnt yet stretch to the Jones bar, you might consider the
    Humpert Space Bugel Handlebar.
    I spotted some on ebay:
    ebay.com.au/itm/200894328442
    These look similar and are of similar dimensions with the main difference being they take a smaller stem diameter size and will need a bush(?)
  • 03-23-2013
    SingleTrackLovr
    Sorry JP I don't understand your question. You lost me with effective toptube and ETT.
    Both my 26"ers have a straight top tube that slopes. I have ~6" when standing over these bikes.
    04 Azonic
    07 AS-X
    The bent toptube on the 29er really helps with stand over clearance. 29ers are taller.
    Was chasing daylight and loosing the race but here is a quick comparison shot. Attachment 783644 and here Is the specs on my fsa bar for scale. I will post finished shots of the hardware with the wtb grips they are similar to the gp1's.
    Hi Unchewable, Thank you, your pict is exactly what I was looking for. I think I will order one of these @ $120 for the Al model.
    Would love to see your bike once you get the bars installed. What grips are you planning to use and will you be wrapping the bars?
    Thanks for the picts that is a very nice bar and you can't beat that price.
    I think I prefer the H over the J. I plan to mount my GPS and headlamp on it.
    I just got off the Jones site and they only offer Paypal.
  • 03-23-2013
    Unchewable
    Sure thing here you go. Attachment 783861
    Here is a close up of my WTB comfort grips. Also I choose the loop bar because non of the other chopped versions fit my shifters the way I liked.
    Attachment 783862
    The grips are great and act as a platform for my elbows when in the aero position.
  • 03-23-2013
    SingleTrackLovr
    Hi Unchewable, Thank you. That looks great.
    I use Ergo grip which should work the same as your WTB's as an elbow platform.
    Ordered the same H bar. I did not like the idea of putting my thumb shifters on the other side either.
  • 03-23-2013
    james-o
    OP - a quick question that I believe is a good test for any bike fit, especially distance riding fit. It's been confirmed by a very experienced bike fitter I've worked with and seems to make a lot of sense. Also related to how I got over my 'climber's back' discomfort on my road bike. Maybe it'll help.
    Sit on your bike or ride as normal if you can ride hands-free. Unweight your hands but keep them over the grips, hovering if you like. Can you keep pedalling without using more than core body muscles to keep you in that position? If so, your saddle is putting your c of g in the right place and you shouldn't get too much hand / arm strain. If not, move it back until you can. You need to be balanced, not propped up by your arms. If your saddle tips you too far forward, almost no kind of short / high stem will correct that error.
    For the back pain, I found (via discussions with an experienced tri-TT rider) it was related to my tight hamstrings / lack of flexibility in this area, hamstrings pulling on my pelvis and causing lower back stress, I was advised to try moving my seat forward to straighten a little the angle between leg/hip and upper body - ie less hamstring stretch. I swapped a layback post for an inline, moved my bar up 5mm to help balance the slightly further fwd c of g and my lower back cramps just disappeared - from pain that made long hilly rides very uncomfortable at the end to hilly centuries in comfort (relatively!). This may be nothing to do with your problems, just saying for interest.
    I realise both these points recommend opposite adjustments to the saddle, but what I learned with all this is that saddle position is key to a good fit - bar position much less so and is only to be set up once saddle position gives you a balanced core / c of g position.
  • 03-23-2013
    JP...
    [QUOTE=SingleTrackLovr;10260266]Sorry JP I don't understand your question. You lost me with effective toptube and ETT.
    Both my 26"ers have a straight top tube that slopes. I have ~6" when standing over these bikes.[QUOTE]
    OK. Effective top tube (ETT) is the distance from your headtube to your seat tube in a horizontal line. Most modern bikes have sloping top tubes, so just measuring the top tube gives you a different measurement to what the actual, or effective, top tube length is. Measure that on your Rocky Mountain, and then your 26" bikes in the same way and compare.
  • 03-23-2013
    SingleTrackLovr
    Hi James, Thank you for the suggestions. I will give the CG test a try on my next ride and adjust accordingly.
  • 03-23-2013
    SingleTrackLovr
    [QUOTE=JP...;10261735][QUOTE=SingleTrackLovr;10260266]Sorry JP I don't understand your question. You lost me with effective toptube and ETT.
    Got ya. Using a steel tape measure, I measured from just below the head tube top bearing to just below the seat clamp.
    Azonic 21" , AS-X 22", RockyMtn 22.5"
    How does the effective top tube of your 29er compare with the ETT of your other mtb's? Is there a major difference? -JP
    So is 1/2 to 1 inch a major difference?
  • 03-23-2013
    Unchewable
    Great info I think you will like the jones bars. That center of gravity suggestion is awesome great info here, what a cool community.
  • 03-24-2013
    james-o
    "So is 1/2 to 1 inch a major difference" - about the same as a degree or 2 of seat angle change, a difference but as reach is affected by seat angle as well as ETT, could be lessened or compounded by seat angle variance between the bikes. Layback vs inline post, seat rail adjustments etc can all account for up to an inch.
  • 03-25-2013
    rifraf
    Hi SingleTrackLovr, at what point of the transaction are you offered Paypal?
    I've just come from the site and am currently unable to find it.:madman:
    I'm obviously looking in the wrong place. I was hoping to use Paypal so I dont have to register and
    drop a whole lot of personal info.
    I just want to be able to click Paypal who drop them the cash and Paypal provides my address.
    At least thats how it seems to work using ebay.
    What am I missing?:confused:
  • 03-25-2013
    SingleTrackLovr
    When you hit pay from the Jones website.
    Paypal is the only choice that comes up or at least that was all that was offered to me.
    They still make you register with them. In fact they don't even have a billing addy same as shipping button so you have to enter your personnel info twice.
  • 03-25-2013
    SingleTrackLovr
    Hi Chewable,
    Since your grips are a little farther back from your old bars did this change your riding position?
    Jones advertizes the grip angle is more natural giving less fatigue on the hands and wrist. What do you think, does it feel better?
  • 03-26-2013
    Unchewable
    It relaxed my fit a bit and I prefer it. If I move my hands up it is a very similar fit to my old bars only issue I had was I had to move my cables up a little to make room for the new bar.
  • 02-14-2016
    ymsetjenesta
    Hi Im trying to find this handlebar so I can buy one. Can you please post a link?
  • 02-14-2016
    vikb
    Which bars? The Jones bars are here: Store - Handlebars - Jones Bikes
    AFAIK you can't get the Titec Jones bars any longer unless you score one used or NOS from someplace like EBay.
