I saw this bike on ebay that sold for winning bid of 842.50. It was fs and ad said frame is a fastrax, the same one used by KONA. They claim was they are same company that makes frames for Kona, but put their own name on it, I guess. They put it under the kona search. Below are items that came with the bike, I think it had no pedals at least picture showed no pedals. My question was this a good deal and if interested in this bike how much would you have bid. I only saw it when it was over.
ITEM
MAKER
MATERIAL
DESCRIPTION
FRAME
"KONA" OEM Factory
7005 Easton Aluminum
Surplus Kona Clump Race Frame
FORK ( Full Lock Out )
Rock Shox
Duke Race 100mm
Lock Out/ Hydra Air/ Climb Contrl
FRONT DERAILLEUR
Shimano
Deore 27SPD
31.8MM, TOP PULL
REAR DERAILLEUR
SRAM X7
SRAM 27SPD
W/O BRACKET, 27SPD
DERAILLEUR SHIFTER
SRAM X7
SRAM 27SPD
Impulse & 1:1® Actuation Ratio
BRAKE LEVER
NAVIGATOR TREK
27SPD/ Hydraulic Disc
6 Piston Haydraulic Disc Brake
FRONT/REAR HUB
SHIMANO
DEORE M510 AS/AZS
14GX36H, M9/M10 AXLE, W/QR
CASSETTE
SHIMANO
DEORE 27SPD
11-32T, 9PCS, CASSETTE
CHAINWHEEL
POSS
CR-03-FX-A2
22/32/44 TEETH
CRANK
POSS
CR-03-FX-A2
180MM
B.B. PARTS
TRUATIV
BB-04-SPL-SLLT-113
CARTRIDGE TYPE
CHAIN
SHIMANO
SHIMANO LX - HG73
110L
FRONT/REAR BRAKE
NAVIGATOR TREK DISC
MX-2 XC
Hydraulic Disc Brake
RIMS
CHENG SHIN (MAXXIS)
A-320 (ETRTO)
559x18, 26"X2.00", DBL WALL
TIRES
HUTCHINSON
F/C-1140N, R/C 1130N
MOSQUITO AIR LIGHT 26" X 2.00
REAR SHOCK
FOX
FOX VANILLA FLOAT
High Pressure Air Shock
HEADSET
AHEADSET
ACB ALLOY/ VP-A51A
INTERGRATED HEADSET, W/CP
SADDLE
SCOTT YZ
Racing Style
W/PROSTATE PROTECTION
ITEM
MAKER
MATERIAL
DESCRIPTION
FRAME
"KONA" OEM Factory
Rock Shox
Duke Race 100mm
FRONT DERAILLEUR
Shimano
Deore 27SPD
31.8MM, TOP PULL
REAR DERAILLEUR
SRAM X7
SRAM 27SPD
W/O BRACKET, 27SPD
DERAILLEUR SHIFTER
SRAM X7
SRAM 27SPD
BRAKE LEVER
NAVIGATOR TREK
FRONT/REAR HUB
SHIMANO
DEORE M510 AS/AZS
CASSETTE
SHIMANO
DEORE 27SPD
CHAINWHEEL
POSS
CR-03-FX-A2
22/32/44 TEETH
CRANK
POSS
CR-03-FX-A2
180MM
B.B. PARTS
TRUATIV
BB-04-SPL-SLLT-113
CARTRIDGE TYPE
CHAIN
SHIMANO
SHIMANO LX - HG73
110L
FRONT/REAR BRAKE
NAVIGATOR TREK DISC
MX-2 XC
RIMS
CHENG SHIN (MAXXIS)
A-320 (ETRTO)
TIRES
HUTCHINSON
REAR SHOCK
FOX
FOX VANILLA FLOAT
HEADSET
AHEADSET
ACB ALLOY/ VP-A51A
SADDLE
SCOTT YZ
Racing Style
