Results 1 to 8 of 8
    will this fit on my Frame?
    will this shock fit on my frame or will it make it sit back too far and put stress on the frame?
    this
    http://www.jensonusa.com/store/produ...i+55+R+08.aspx
    on this
    http://bikeisland.com/images/09trailds8.jpg
    thanks
    There's no app for this.
    Reputation: JimC.'s Avatar
    No it won't
    your bike is designed to take a 120mm fork, the new one is 140mm, and that's without knowing the axle to crown (A-C) measurement. I'll let you do the checking though. If it's longer and I think it is, then that will add to the rake/chopperization of the Motobecane.
    There are lots of deal around for Fox Float RL 120mm forks that are OEM, those will work for you.
    Jim
    The White Jeff W
    Reputation: jeffw-13's Avatar
    You're frame is spec'd for up to 120mm travel so the 140 is probably gonna be a no go.
    Up to 120mm travel in the front and in the rear
    You don't like the Reba?
    No moss...
    Quote Originally Posted by jeffw-13
    bikesdirect specs it with the Dart 3, I'm not sure what he's got, whatever, the new one is too much travel. Jim
    does the shock above not support disc brakes?
    that should fit but
    you need to check the reviews to see if it will suit your needs. Jim
    http://www.mtbr.com/cat/suspension/2...4_6513crx.aspx
    Reputation: dnlwthrn's Avatar
    Quote Originally Posted by Motobecanefantom
    Read the fine print... 6" Post mount for disc brakes.
