Results 1 to 3 of 3
    mbtr member
    Reputation: scottzg's Avatar
    Why do seat angles and stem lengths change for different size bikes?
    I understand why sometimes really small bikes or 29'ers will steepen the seat tube and push the fork forward- to preserve the reach and fit the wheels under the rider. But a lot of times even on the medium-xl sized bikes they will keep lengthening the stem and futzing with the angles through all the sizes. Why? It makes for a bike that handles differently in each size.
    Klein and K2 are two examples of companies that do it, but i know there's more.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Bicyclochondriac.
    Quote Originally Posted by scottzg
    First of all, larger bikes handle differently, anyway. You are lengthening the top tube and wheelbase. Also, your COG is higher, and when you climb, with a similar length CS and seat angle, you are farther over the back wheel.
    As far as the stem, if you are taller, and on a longer bike, and kept the same stem lengths, then more of your weight is farther behind the steer tube. A longer stem shifts the balance back forwards a little. This is one of the reasons I shake my head when people talk about the best stem lengths without taking about how big they or their bike is.
    As far as the seat tube angle, 2 possibilities come to my mind. First, as you get a longer and longer seat tube, the saddle is farther and farther back over the rear wheel, so maybe the steeper seat tube is to alleviate that. But also, I wonder if tall people are not proportioned slightly differently (femur / feet / tibia) on average from shorter people?
    mbtr member
    You answered my question, but in a strange way. I think every XL bike i've ridden (well, both) that had the geo tweaked from the medium have kinda sucked. Much too nervous and over the front wheel. I guess you can't ever really know how something will work for someone else, you can only make an educated guess.
    I've been thinking about geometry and fit a lot lately.
    Mikhail Kalashnikov
