Results 1 to 5 of 5
    Tomac Eli bearings
    Hello all. I tried a search but came up with zip.
    I recently picked up a clean, uncracked Tomac Eli frame second hand and need to replace the main pivot bearings. I have emailed the person on the Tomac website but have not heard back yet.
    By chance anyone here have a manual with the specs on the bearing size or know of a place that might stock this?
    Thank you
    Reputation: Dougal's Avatar
    Can you read the code off the bearings?
    Owner of www.shockcraft.co.nz and NZ Manitou Agent.
    www.dougal.co.nz Suspension setup & tuning.
    SPV Devolve
    Quote Originally Posted by Dougal
    Negative that I can not.
    I did email Tomac and received a response on Sunday which is really cool. I got type/part numbers in an excel spreadsheet and was able to locate all the bearings I needed online.
    Thank you.
    Before you do any service, make sure you check the frame for cracking anywhere.
    Reputation: HotzKiss's Avatar
    Tomac Eli Bearing
    Quote Originally Posted by boudroux
    Thank you.
    Do you mind PM me the list too, i did email Tomac but no reply on the bearing parts neither the shock dimension
    Do you know the shock dimension? 200 x 50?
    thanks
