Results 1 to 12 of 12
    Threadless headset and Integrated headset?
    Okay, I currently have a 03 GT Avalanche, I installed a FSA DH Pig pro threadless headset, I found a deal on a 04 Avalanche frame (thicker downtube, size large (i'm 6'0 and current frame is a SMALL, no vbrake rear bosses, cheap) so I bought it, stripped it and currently in primer phase. And I just noticed that the new frame is for a integrated headset, is there a way to use my current one or will I need to buy a brand new integrated headset?
    Reputation: TraumaARNP's Avatar
    Quote Originally Posted by ricky916 View Post
    Yes, you will need a new integrated headset.
    Okay thats what I thought, thanks!
    This little project just keeps adding up lol
    Former Bike Wrench
    Quote Originally Posted by TraumaARNP View Post
    I believe the GT uses a Zero Stack or "Semi-Integrated"...this is different than a full integrated.
    Reputation: phbike's Avatar
    If mtbiker72 is correct and it is a zero stack, i don't think it will, but I'm not totally positive of that. you'll need to look for specifically a zero stack headset. I found an aheadset zero stack on amazon for 25ish including shipping.
    So then this will?
    http://www.amazon.com/Aheadset-Zero-...1203674&sr=8-1
    I'm probably going to take it to my LBS and see what exactly one so I don't order the wrong one and have to send it back.
    according to this link: http://velospec.com/bikes/gt/avalanche10disc-2004 it does use a zero stack and I'd get a zero stack for it. That was the exact one I found on amazon. I'm starting to build a hardtail frame myself that requires a zero stack and will get that one as well. good luck!
    New question here.
    Quote Originally Posted by mtnbiker72 View Post
    You're correct, sir. I can get confused with zero/integrated/internal/standard blah, blah, blah....I'm even more confused now after reading why Chris King doesn't make anything but standard headsets....or does he?
    Quote Originally Posted by phbike View Post
    Got it at my lbs (mad cat sacramento ftw) for $26 after tax its boxed as giant but made by fsa (tagged on it) so now hopefully I can get started on making some progress now that paint is done.
    Thanks to everyone who replied.
    Sent from my HTC EVO 4G using Tapatalk
    still
    to much work
    ....and now for some integrated Ti headset candy....
  1. 1-1/4" threadless headset
    By muddybuddy in forum Vintage, Retro, Classic
    Last Post: 09-22-2011, 03:26 PM
  2. Threadless headset adjustment question
    By mipi in forum Bike and Frame discussion
    Last Post: 03-31-2010, 01:11 PM
  3. Replace Headset/Bearings on Integrated Headset?
    By iRoNeTiK in forum Bike and Frame discussion
    Last Post: 12-31-2009, 12:45 PM
  4. Integrated Headset vs. standard threadless?
    By woebegone in forum General Discussion
    Last Post: 03-12-2009, 01:21 PM
  5. Threaded/Threadless Headset
    By Ottoreni in forum Beginner's Corner
    Last Post: 03-22-2004, 11:27 AM
