Results 1 to 5 of 5
    Feb 2013
    Standard headtube with tapered steerer?
    I have a 2011 trek ex5 with a standard headtube that takes a 1 1/8 steerer and standard external cups headset. I think the guy at the LBS misunderstood me when we were talking about fork upgrades. He told me that I can get a headset that will allow me to run a 1.5 tapered steerer. I can not seem to find this type of headset. Can y'all help me?
    Let me make sure I am clear. I do not have a tapered head tube, I have a standard headtube with, I believe, a lower diameter of 39 mm. The cups and bearings on both ends are the same size. Is there a headset that actuall allows me to run a 1.4 tapered steerer?
    Reputation: BacDoc's Avatar
    As far as I know you can't run a tapered fork in your head tube. There are adapters to run a straight steerer in a tapered head tube though.
    It can't be done. You can put a straight fork in a tapered headtube but not the other way around
    Jan 2009
    I'm not familiar with Trek but this *should/could* work if your headtube is 44mm.
    Cane Creek 40 Series 44 Tapered Headset - Competitive Cyclist
    I've seen it done- but it required heavy fabrication - Today's DIY project...
  1. Tapered headtube and standard steerer question
    By dtsabas in forum All Mountain
    Last Post: 08-29-2012, 06:39 AM
  2. 44mm headtube and a 1.5" non-tapered steerer, headset?
    By haymitch in forum General Discussion
    Last Post: 07-26-2012, 01:30 PM
  3. Straight steerer fork in a tapered headtube?
    By Yuri Natenpuhl in forum Shocks and Suspension
    Last Post: 04-26-2012, 03:56 PM
  4. Standard Fork Steerer w/ a Tapered Head Tube?
    By durkind in forum Shocks and Suspension
    Last Post: 10-07-2011, 11:47 AM
  5. Will tapered steerer forks become the new standard?
    By jocko in forum Frame Building
    Last Post: 07-02-2011, 03:57 PM
