Results 1 to 8 of 8
    Oct 2014
    Specialized Hardrock Front Derailleur
    I recently picked up a Specialized Hardrock older model frame. The problem I'm having is figuring out how to hook up the front derailleur. There are two slots/guides under the BB. It seems like the guide closest to the chain ring should go to the rear derailleur however the front derailleur is a bottom pull and if you use the remaining slot it moves the cable too far over ( it seems) to be able to hook up to the bottom pull front derailleur. Hope this makes sense?????
    Thanks guys
    B A N N E D
    Photos might be helpful.
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    What do you mean "it seems too far over"? Does the cable drag on anything?
    Reputation: watts888's Avatar
    Oct 2012
    general picture. If your bike is similar, the front derailure cable should go on the longer plastic pull, furthest from the crankset.
    Oct 2014
    No man. I finally figured it out. The guide below the bottom has two slots. One nearest the chain goes straight back to the rear derailleur and the other one is on a major angle and goes over to just about where the derailleur cable goes... so it will make it to the front, bottom pull derailleur okay. When I first looked at it all I saw was the fronts of the slots... didn't notice that the front derailleur cable was on a major angle. HTH Thanks anyway man.
    Oct 2014
    Got it man thanks... on mine the front D. slot cuts over on a severe angle... which works for me. When I first looked at it all I looked at was the front of the guide's slots figuring they parreleled but on closer inspection found out that was not the case. Newie here obviously. Thanks brol
    Oct 2012
    front derailure setup is easy, just have to be careful and follow the correct sequence of setting it up. youtube videos help a lot.
    1. height and clearance of largest ring.
    2. align with chainrings
    3. adjust lowest chain/ring stop and attach cable
    4. shift the lever a single gear and adjust cable adjustment barrel till the chain shifts
    5. test
    If the early steps aren't done right, start over. You can't adjust out height or alignment problems.
    Oct 2014
    Thanks man. Excellent advice. I'll follow it to a tee.
  1. Specialized Hardrock; Shimano Alivio rear derailleur help
    By cs641 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-13-2013, 06:34 PM
  2. 2009 Specialized Hardrock Front Shocks
    By BRWhelan in forum Specialized
    Last Post: 11-02-2012, 01:27 PM
  3. hardrock front derailleur ?
    By pebblehoppertj in forum Beginner's Corner
    Last Post: 05-30-2011, 05:44 PM
  4. Replies: 1
    Last Post: 03-22-2011, 11:20 PM
  5. Replies: 2
    Last Post: 02-26-2011, 05:00 PM
