    spacer stack height and handlebar rise queries
    Hi,would like to know if a 10mm spacer stack height with a 20mm riser bar have the same cockpit height with a no stack spacer and a 30mm riser bar?my current setup is the former and I'm planning to get a 30mm rise renthal bars.
    Would there be any difference if the rise(cockpit height) comes from the bar and not with the spacers?
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    In theory there's a slight difference in the resulting height, because the spacer stack is at an angle (same as headtube). In practice it won't matter much, and it doesn't go without saying that the bar is at a certain angle either.
    This site might help you Stem Chart
    Thanks for the chart just what I need at the moment for a new build
